Question about AT&T Nokia 6085 Pay-As-You-Go Cell Phone - Black
Phone rings i answer it no voice incoming or out going but when i put it on speaker it works ???
    Novelist:
  • 81 Answers
There is a long shot chance that the volume on that speaker has been muted and you should try to increase the volume while the internal speaker should be working. If your volume level indicate is set to max and you still have no sound coming out it then I would assume the speaker is dead. Most phones have 2 sets of speakers and it is very possible that one can fail and the other can work fine. If your phone is under warranty contact the manufacture for repair info. If it is not then post the phone's model and I can try to help you locate the replacement part.
Posted on Jul 28, 2009
3 Suggested Answers
  • 75 Answers
SOURCE: phone doesn't ring. Incoming calls automatically go to voice mail
might be any software trouble check with service centre
Posted on Dec 01, 2008
shadow83
  • 496 Answers
SOURCE: cant hear incoming voices unless i put it on
this sounds like a broken earpiece speaker you might be able to find a replacement one on-line and replace it or if its still under warranty send it back in and get it replaced
Posted on Sep 25, 2009
NEC DTU-8-1 office phone system: The v-mail is set up on the phone, but incoming calls never go to voice mail. The phone just rings. How do I fix this?
try speaker 45, or 43 then 200. you need the voicemail pilot number which is usually 200 but could be anything. try the code at a phone the works and the display should show you the pilot number, then do speaker 45 or 43 plus pilot number and hangup
Nov 20, 2016 | NEC Lands Phones
Incomeing call going to voice mail and phone not ringing
if you diverted to voice mail send #21# to deactive all diverts if your answering machine is on turn it off setting > application setings > call > all calls > answering machine > activation > off
Aug 08, 2011 | Samsung S8300 Cell Phone
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
No voice received on incoming calls
try useing it on speaker phone..if it works there then the problem is in the speaker..it is eeasaly replaced also you can try and do a software upgrade..
Oct 07, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Cant hear incoming voices unless i put it on speaker. Can hear rings and all phone bells and whistles though. just not earpiece volume for incoming calls unless on speaker
Sep 25, 2009 | Motorola Mobility RAZR V3
Ringing & voicemail transfer for DCS
I would need to know what group your lines are ringing in to.(Look at the phone display on any ringing phone and it will tell you the "ringing group" probably 500, 501 etc.) With that known we can add all three stations to that group and mark the "NEXT" option to go to station 202. Just have 202 forwarded to voice mail on a NO ANSWER condition and it will work for you
Nov 14, 2008 | Samsung DCS 12 Corded Phone
How to prevent HP 3380 All in One Printer answering voice calls
If you have call waiting on your phone service you can call your phone company and get "personal ring" service. It will cost a couple of dollars extra a month, but they will assign you another phone number and it will have a different ring style to it. Then you can set the ring type to the type of ring they assign you.
May 31, 2008 | HP LaserJet 3380 All-In-One Printer
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
No voice during calls both incoming and outgoing
Have the audio jack repaired it's not making contact on the connecting plates properly. You ould have a go at this if you are very good with fine electronics
Nov 26, 2006 | i-mate PDA2k Pocket PC
AT&T Nokia 6085 Pay-As-You-Go Cell Phone - Black Logo
90 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
