Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Makita BML 185 cordless flash light
Light just goes off after 5 to 10 seconds after turned on. The battery is fine.
Thanks for any help
  • Anonymous Jul 26, 2008
    I have the same problem, started today after only using about 20 times, the flashlight is about 7 months old.
  • Jebjd Nov 29, 2008
    Mine does the same thing, battery fully charged. Jebjd
  • 619 Answers
Replace charger/ burn or busted
Posted on Jan 01, 2008
The problem is that the battery is almost completely discharged. Makita's lithium-ion batteries have a built-in safety circuitry that shuts off the light when the voltage reaches a low cutoff level. So try replacing with a fully charged battery and see if it resolves the problem.
Posted on Aug 06, 2008
  • rkfix Dec 19, 2010
    True story about the battery being low. Had the same problem, put in a freshly charged battery and Vualla! ...Flashlight stays on
    Thank you for the info...
    What, 2 years ago! Damn...
Makita bml 185 swivel head removal
You may have to pry it apart. I recently had one of those and had the same problem. Couldnt find how to take it apart with out prying it.
Jun 02, 2013 | Makita 18V Lxt Lithium Ion Rechargeable...
Green flashing light
battery is open circuit or charger not working Re: Jeff
Apr 07, 2012 | Makita 18V LXT Lithium - Ion Cordless...
I have an older basic makita cordless drill worked fine until now battery charged and it doesnt work. charged again. still nothing- except the built in light on the drill lights up weird
if the battery show good on the charger and you have a light i would check the switch. you can do a hot wire connection to check it. you need you battery and two wire connedtors. disconnect your switch and hook your battery straight to the motor. if the motor turns it is your switch. if not, that's bad, probably the motor is gone.
Aug 15, 2010 | Makita Drills
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita Cordless drill light stays on after releasing trigger
THe light will drain the battery. Your issue resides in the electronics circuit. The light itself is an LED bulb, not a whole lot of current draw. Your best bet is to take it to a service center and have them warrenty the board for the electronics. Can't fix this with conventional tactics. If the board is bad, they will replace it free as a manufacturers defect.
Jan 17, 2010 | Electrical Supplies
I need to find a manual for the makita 18v lxt angle grinder. my problem being that when i put the battery on the lights flash up red and during use the lights do not work at all. please help.
Hi, Don't stress, its working fine. The grinder has a sort of self test when you put the battery in, it blinks. What you don't want is the light to come on when you are using it. That means that you are bogging it down and if on for 30 seconds ( if I remember right) it will shut the grinder off until you reset it by turning it off and then on again. So no worries!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 26, 2009 | Makita 18V LXT Lithium Ion Cordless 3/8...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
665 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
