Question about Hotpoint WMTL80 Top Load Washer
Hotpoint WMTL80 washing machine does not complete cycle and program selector switch continues to rotate.Doing reset does not solve problem!! bill mack
  • 76 Answers
Chances are the wiring underneath to the transmission solinoid has broken. You'll have to drain the washer by laying the drain hose on the floor in a pan. Then turtle (flip on it's side) on a pad/carpet carefully and remove the back panel and trace the wires with a flashlight, If you find the break you can try a heavy duty **** splice but my experiences tell me adding wires to lengthing that cable is a better choice.
Posted on Jul 28, 2009
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Mt WMT05 Hotpoint went mad whilst on spin, managed to find out that one of the suspension springs had broken, ordered some new ones and replaced both, it now spins ok but when put on wash (all the...
The tube goes to the pressure switch and to the bottom of the drum, if it is not connected the machine will continue to fill as the switch is not being told it is full and now needs to change to next part of wash.
Pressure switch is a circular unit located at the top of the machine and has a couple of wires to it.
Dec 21, 2012 | Hotpoint Wmt05p Wmtl79 Wmtl80 Washing...
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Jun 25, 2008 | GE WBSR3140DW Top Load Washer
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMTL80 Top Load Washer Logo
145 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
