What does the 4th light ,not counting the 2 larger button, means
    Problem Solver:
  • 10 Answers
4th light? plz be more specific and i might be alble to help you thank you
Posted on Jul 28, 2009
Chevy equinox. Location power door lock relays .i dp not see them
On the engine fuse and relays box facen towards the car front and counting from left to right you have 1 big gray 2 small gray 3 ********* 4 big gray now from the 4th big gray you count vertically from back to front 1. the 4th big gray that we mentioned before 2. small gray 3. small gray 4 small gray the 3rd small gray (the middle of the 3 vertical small gray relays) is what you need :)
Apr 25, 2016 | Cars & Trucks
I have a arrow light on the instrument panel down where all the other lights are like the battery light an oil light ect. Anyway sometimes that arrow light flashes and wondering what it means an what need...
4th gear disengagement:
The 4th gear is engaged automatically after the transmission has shifted through 1st, 2nd and 3rd gears
at certain speeds and loads. By pressing in the button at the rear of the selector level, the 4th gear can be
disengaged, thus providing a three-speed transmission. As a reminder the
? light on the dashboard
glows. By pressing in the button again, the transmission reverts to four-speed operation and the
light shuts off.
This is straight out of the owner's handbook. What this indicates is that there may be a problem with the shift solenoid. On the highway, does is seem to rev high? Can you press the button on the shifter and have the light go out? let me know.
Aug 13, 2011 | Volvo 850 Cars & Trucks
When using a jumper wire to retrieve ABS trouble codes on a 2002 Trooper 4 wheel drive how is the DLC numbered? I mean which pins do I jump? And when I do jump, Will the ABS light flash te codes....
ok, there are 16 pins in the DLC you want to jump #4 and #12 as you look at the connector from left to right top row is 1-8 bottom row from left to right 9-16, both rows the 4th pin jump them together. then count the flashes all codes are 2 diget ( example flash-flash pause flash-flash = code 22 )
Feb 17, 2011 | 2002 Isuzu Trooper
Lost instructions for photocell Type:ET321
Here is how it works. The push button repeats itself in following sequence (must plug in).
F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off.
1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings.
A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (on from dust, but off randomly) time shows no pattern to outsiders.
d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion.
1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Dec 08, 2010 | Impact First Alert Outdoor Digital...
What does it mean when the airbag light comes on?
Either the sensor in the bumper has lost communication with the airbag module, or the airbag module is bad, or the airbag package itself is damaged somehow.
Sep 09, 2010 | 1995 Lexus ES 300
Instruction for first alert et321 timer
F: timer is off.
Dec 13, 2009 | First Alert Hardware & Accessories
The 4th light on the left hand side is on and i dont know what this means, car did not come with the manual so i really need to find out what this means.
Forth light on left, counting from bottom is the seat belt light-should look like a stick person facing forward with belt across them. If it is the forth light on left, counting from top it is the front air bag light-looks like a stick person facing sideways with a solid circle/ball above their lap. My airbag light, in my 2002, stays on for months and then will go off for months, then comes back on again. Has been doing this since it was quite new.
Sep 27, 2009 | 2002 Ford Escape
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
4th gear engaged
There is a button on the side of the "shifter" knob that engages and disengages 4th gear.
Dec 20, 2008 | 1993 Volvo 940
2000 es300 lexus auto w overdrive button overdrive 4th gear not work
There isn't anything wrong with your car. This is perfectly normal. I have a 2000 ES300 as well as other people that I know and it operates in the same way. Overdrive doesn't mean the same thing for every car or transmission. In our case overdrive is simply a reference to the top gear which is 4th gear. When you switch overdrive off(which is depressing the button causing the O/D OFF dash light to illuminate,) the highest gear becomes 3rd because you turned 4th gear or overdrive off. The application scenario for this is usually mountainous terrain where a lot of uphill driving makes it more feasible not to up shift into 4th gear while ascending and descending. It will not switch back to overdrive or 4th gear until you re-engage it by turning the overdrive back on or repressing the button. Again, when the O/D OFF dash light is illuminated, overdrive which is 4th gear is off and the highest gear will then become 3rd. It will never shift into 4th gear while this light is illuminated or overdrive is off. When you press the button and the O/D OFF dash light is NOT illuminated overdrive is on and therefore it will shift into 4th gear as usual. This applies to all 97-2001 ES300's and probably any other car you drive tat exhibits this same type of change when overdrive is turned off.
Nov 20, 2008 | 2000 Lexus ES 300
35 people viewed this question
k24674
jasbo
jasbo
