Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
GE profile refrigerator. Water doesn't dispense even after replacing filter. Water pressure? If I remove the filter, left it out for a few seconds, put it back in, then I got some water dipensed. Then It stopped again. The hose in the back wasn't kinked.
  • 76 Answers
The water line is freezing up in the Refrigerator, trace it out and you'll find it.
Posted on Jul 28, 2009
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
No dispensing water...GE refrigerator
There may be an interlock switch on the housing where the filter or dummy stopper is inserted. If this interlock is not satisfied, then the water dispenser won't turn on. This would prevent water from spraying all over the inside of the refrigerator if the filter is not seated properly. Check to make sure the filter or plug is inserted properly.
Apr 01, 2014 | GE Refrigerators
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
Ge profile refrigerator slow water dispenser
you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Water dispenser quit working after a few hours after replacing filter. Have water pressure up to filter but nothing making it to the dispenser. Could it be that the new filter had something in it and...
There are 3 types of the PSW26P. They are basically the same when it comes to changing water filters. I do not recommend placing air into the water system, I believe that is what at this point is the problem. After changing water filter there is a period of time that you need to push the dispense water switch to allow for the air that is trapped in filter to purge. One moment I will send links, Sea Breeze
Feb 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
334 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
