Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
No water to icemaker What do I do?
Ice maker is not making ice and there is no water coming to ice maker
  • 76 Answers
Trace the water supply line looking for kinks behind the fridge, also check the water supply valve and make sure water flows when disconnected from the unit.
Posted on Jul 28, 2009
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Ice maker not making ice
    The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
    May 10, 2012 | Kenmore Side by Side Refrigerator
    Ice cube maker not making ice
    feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
    Apr 29, 2010 | Maytag MFI2568AE Side by Side French Door...
    Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
    the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
    Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
    No Ice is being made
    Ice maker solenoid ...side..water side ok replace
    Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    No water coming down tube in kenmore ice maker
    Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
    Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    The ice maker on my refrigerator Model GSS22JETACC is not making ice. The on button is on.
    check the water valve to the ice maker it will be the one with the 1/4 inch line unplug the wire connector to the valve and use a cheater cord to apply power to the valve if you get water into the icemaker cavity then the icemaker is the problem
    if no water comes into the ice maker then remove the 1/4 inch line from the valve apply power to the valve if water comes out of the valve then the fill line into the icemaker is frozen unthaw it
    if no water comes out of the valve replace the valve
    Apr 26, 2008 | Refrigerators
    KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
    224 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Todd Arndt
    Todd Arndt
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
