Question about Refrigerators
I have a Monogram ZISS48DMASS. Condensate water builds up in the bottom of the refrigerator side. It appears that the drain get frozen or is plugged up. I agree that it is a pain in the **** to get to. What is the little gizmo on the end of the drain hose? Should I clear it out thru there or remove the panel under the evaporator? How do you remove the gizmo at the end of the drain tube? Thanks, Bill Pompa
  • wpompa Jul 28, 2009
    Before I can pour water in the drain line I need to get the gizmo off the end of the drain hose. What is it for? Does it just pull off? I haven't been able to find it on a parts diagram.
    Thanks
  • wpompa Jul 29, 2009
    Thanks for explaining what the hose end gizmo is.
    I will remove it and use the CLR.
    Thanks
    President:
  • Refrigerators Master
  • 1,723 Answers
Give it a good cleaning and leave the end on there, it's supposed to be there. Give it a dose of CLR do remove calcium build up. The water comes from the defrost cycle on the fridge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 28, 2009
  • Craig Butler
    Craig Butler Jul 28, 2009
    It is blocking element in the end of the
    drain hose inserted to prevent outside air from being introduced into
    the drain hose which would let warm air up to the evaporator coil. It's kind of a one way valve to let the water out and keep the warm air in.
  • Craig Butler
    You should be able to pull it out of the hose.
  • 2,200 Answers
Hi
You can often clear this drain by pouring a small amount of warm water into it. This will clear any ice and help to open any contraction that has occurred in the drain under cold temperatures. Another effective method is to use something flexible like a drinking straw to clear the drain. There should be no need to dissassemble the drain itself.
Condensation is often caused by high humidity or leaving the door open on the fridge. If you find that condensation persists after clearing the drain its important to chech that the door seal is in good condition as these are often at fault and can leak resulting in a build up of condensation. A new door seal can usually be bought for around $20.
Hope this helps. Please do rate my answer. Many Thanks
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
Water on the bottom of friezer
Hello Geens
My name id Peter. I am a retired field service refrigeration technician.
You have a frozen condensate drain. About every 8-10 hours your refrigerator shuts down for about 20-30 minutes. At this time your defrost heater (Under your cooling coils) turns on and melts the frost off the coils. This condensate goes down your condensate drain. If the drain is frozen, the condensate has no where else to go except on the bottom of the freezer.
The freezer drain is behind the back wall of the freezer. You need to clear the ice out of the drain and put a heat sink in the drain hole.
You may try using warm water and a hair drier, but be ready for a small flood.
You did not give a model number, so I can not tell you how to repair.
Nov 12, 2014 | Refrigerators
I have a GE monogram side by side refrigerator and water has started collecting in the "express chill" drawer at the bottom of the refrigerator side. It appears to be collecting in the "ceiling" of th
water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | GE Monogram Side by Side Refrigerator
It is leaking water out of the bottom. It does not appear to be coming from inside the fridge or freezer. It does start on the bottom on the freezer side.
Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator.
Apr 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water doesn't drain
I assume you mean from the freezer. Condensate drain is clogged. The drain is at the back, bottom inside the freezer and is probably frozen.
Mar 03, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Bottom of freezer in the side by side builds up with ice, then water leaks on to the floor
We have a defrosst drain problem we will need to work on, WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze
Feb 06, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
My amana frige leaks at the bottom, it is a bottom freezer frige, I moved it lately because I am laying laminate floor, any solutions?
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Oct 16, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Condensation at top of inside refrigerator
you have a drain hose from the top back of the freezer down to the condensate pan on the bottom of the refrigerator near the floor
this hose is blocked causing ice to build up behind the rear inner wall.
remove the back of the freezer wall and using a funnel pour hot water in to the hose to clear the condensate hose also remove all the ice behind the wall; remove the back cardboard to see the water come through the hose into the condensate tray when you pour the water it should pour right through if it's clear
Aug 31, 2009 | GE Refrigerators
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
I have ice build up at the bottom of my frigidare freezer compart
Sounds like the defrost condensate drain behind the rear panel inside the freezer is frozen over. You will need to unplug the refrigerator and remove the panel. Defrost with a hair dryer and pour warm water into the tray that collects the defrost condensate and takes it down to a pan below your refrigerator to be heated and put back into the air inside your home. If for some reason it is not ice blocking the opening you will need to use a wet and dry vacuum cleaner to try to dislodge whatever is blocking the flow. Let me know what you find, Thanks, Sea Breeze
Jul 21, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
