Question about Maytag Dryers
Maytag model mde 4806 ayw ... will not shut off
Maytag model mde 4806 ayw ... will not shut off when running on auto temp.. drys well but won't shut off????
Thank You..
royboy
5 Suggested Answers
SOURCE: changing heater element on maytag mde 5500 ayw
called sears repair to handle the problem!
Posted on May 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: maytag dryer access to the thermal sw
moz-screenshot-4.pngThe thermal limit mounts beside the heater element chamber and is held to it by the same screw that holds down the element.
The kit comes with 2 limits one fer gas the other fer electwic.
Posted on Sep 03, 2009
Testimonial: "well my model must be older because it has a barrel heater in the back and the front comes off with four screws in the door area "
Daniel S
  • 4323 Answers
SOURCE: dryer won't heat maytag neptune mde
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 20, 2010
mc1bean
  • 3053 Answers
SOURCE: I was looking for specifications (capacity in
Hello, sncrexer I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
My Maytag electric dryer model# MDE 4658 AYW does not dry my clothes (no heat) and the light no longer stays on when the dryer door is open. started happening after i turned all fuses off in the house. can...
I gotta assume you're joking since it looks like you're asking why the dryer isn't working when you've turned all the power off in your house.
If this is the case then the only way your dryer is going to function is if you bought it with the optional Maytag Cold Fusion power supply. Or you could turn the power back on...
Oct 30, 2013 | Maytag Dryers
Maytag Legacy gas dryer shuts down
too complicated the inner machinery is not working nome its bettter to go for a newer one
Dec 16, 2007 | Dryers
Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Dec 12, 2007 | Dryers
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Dryer won't heat maytag neptune mde 5500 ayw
Hi
Electric Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer access to the thermal sw
Sep 02, 2009 | Maytag Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
