Question about Philips Magnavox 51MP392H Rear Projection Television
Phillips Magnavox 8p6054 60in. has a red line in the center
The line looks kindy like the joker smile in the center of the screen also has a spot of blue in the left side on top of the red and the picture is bright we tried adjusting it but no luck
Philips/Magnavox 60" 8P6054
U just want to take peoples money this site sucks
Posted on Jul 29, 2009
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
http://servicemanuals.vstore.ca/
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51" Rear Project Red Streaks
Sounds like the convergence IC's went south.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
