I have a Zyxel 660 router from Post Office broadband. My Iphone and office laptop (dell winXP) get the signal from the router and i can access the internet, but the other two laptops (lenovo and HP, winXP) in my home and a Nintendo DSi do not manage to catch the signal, it does not show up at all. The internet works fine when connected directly to the lan cable. I have checked all the configurations on the router but i cant seem to find the problem. anyone else has had any issues like this?
Disable the network adapters on the laptop via device manager and then enable again. If this does not work reinstall the network drivers and see whether it helps.
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Zyxel Prestige 660HW Wireless
Hi... I wanted to setup my (borrowed from someone) P-660HW modem and it kept asking me the 3 things:...
(More)
Hi... I wanted to setup my (borrowed from someone) P-660HW modem and it kept asking me the 3 things: system password, username, password... I pressed the reset button so the it turns back to factory default settings...but after that its not turning on :( The handbook says... the power light will blink on power on... and then become steady...instead it blinks on power on and then goes off :( Any bright ideas ???
I upgrade the Firmware of Zyexel 660hW after that i was waiting for the device to boot back ....
(More)
I upgrade the Firmware of Zyexel 660hW after that i was waiting for the device to boot back . unfortunately it didn't reboot, i Did a physical reboot after that it no longer working only the power led is flashing
i still cannot remote cctv even i input ip on default server in NAT. can u help me ? i use Zyxel...
(More)
i still cannot remote cctv even i input ip on default server in NAT. can u help me ? i use Zyxel Prestige 600 series
I'm not able to go wireless with my Macbook (I am able to connect via hardwire). My modem is a zyxel...
(More)
I'm not able to go wireless with my Macbook (I am able to connect via hardwire). My modem is a zyxel 660HW - T3 kevin
I want to use the address "localhost" for testing web pages. However localhost is blocked...
(More)
I want to use the address "localhost" for testing web pages. However localhost is blocked despite of 127.0.0.1 is incribed in the hostsfolder. I can ping my PC but I cannot connect using the telnet option. However I can open with telnet the Prestige Menue. I suppose I have to configure something there to enable loopback.
In fact I am using Zyxel Prestige 660WH Wireless Router! Please apologize this error.Gakusei
