Question about Microsoft Windows XP Home Edition
I have 20mb broadband but only 300kbs download speed
HI babb i have this problem ive written above and apparently its to do with the mtu which needs to be reset; any advice would be great as im paying for 20 mb and only getting 2mb provider says its my computer settings re mtu they told me to ring a number costing £1 oo per minute and they would talk me through resetting the mtu.they say this will give me the speeds im paying for any ideas?
  • 2,961 Answers
I personally have never known that changing the MTU setting can speed up your connection, as the MTU is the maximum transmition units that is sent to your pc from each web site and if the MTU setting is incorrect then some web sites will not load on your explorer page, the speed at which you download the page will not make any difference.
If you are supposed to get 20MB speed then you must be on cable and not ADSL as ADSL is a max of 8MB, so i would ring up Virgin or whoever and check the speed you should really be getting.
See these details posted on the netgear site, and you'll notice there is no mention of speed:-
Details About MTU
A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same — large — value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc.
  • Tweaking MTU size may work well in one situation, but cause performance and connection problems in others.
  • When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU.
  • Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: How-To Configure Broadband Connections Using PPPoE.
  • Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer.
Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size:
  • 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches.
  • 1492. The size PPPoE prefers.
  • 1472. Maximum size to use for pinging. (Bigger packets are fragmented.)
  • 1468. The size DHCP prefers.
  • 1460. Usable by AOL if you don't have large email attachments, etc.
  • 1430. The size VPN and PPTP prefer.
  • 1400. Maximum size for AOL DSL.
  • 576. Typical value to connect to dial-up ISPs.
Posted on Nov 22, 2007
  • andrew pester
    andrew pester Nov 22, 2007
    You mention download speeds, this is the speed that a file will download and can vary from one site to another, you may be refering to the speed that shows when downloading a file or programme, connection speed is different relating to the connection from your isp, speeds from other servers for downloading will only show as 300kbps etc.
I have a Motorola WR850G router which works just fine for broadband internet access for our laptop and our desktop. We are trying to connect xBox Live and we are getting an error message that Maximum...
Starting on page 3-3 of the WR850G user manual, there is a setting for "PPP MTU".
Whether or not this will change the overall MTU of the router is not clear. Apparently the default setting is "0", which I would guess is automatic. I would try changing the setting to 1500 and work your way down from there until xbox live is hopefully satisfied.
Good luck...
Dec 29, 2010 | Arris Wireless G Broadband Router (wr850g)
Check your broadband speed and report it as a Slow/Not Spot
I have a maximum download (connection) speed of 3.5MB at my exchange which is a Local Loop Unbundling or LLU from which I live about 5km as the crow files.
My expected maximum will be only 70% of this at about 2.5MB due to signal to noise ratio loss on the BT line, dont bother trying to change your MTU or any TCP tweak settings you will probably cause more problems with the speed becoming lower maybe even cutting yourself off your own broadband connection
However most ISP use Local Loop Unbundling is the process by which third party networkoperators are able to install equipment in to BT telephone exchanges in order to provide their own services without having to touch BT's network. Only the copper pair from the exchange to the premises, which remains the property of BT, is used by the third party. Use SamKnowsBest to check what options you have at your local BT exchange
BT copper line MAX is only 8MB irrespective of the the LLU that you use this means your ISP hardware.
Optical Cables MAX is 20MB and only Virgin Media in the UK can use this transmission medium.
I used to get only 750kbps which is not even 1MB now I can get double that between about 1500kbps - 1800kbps which is still only 1.8MB depending upon the time of day.
Also make sure that your connection is not shared with another user they will steal your bandwidth ensure that if you are using wireless use a WEP or even better a WPA-PSK encryption. Close all instances of P2P or FTP uploading during the speed test.
My Results as a comparision 750 Kbps 1500 Kbps 1800 Kbps
There is not a lot you can do other than report this slow speed to this website the more they can build up a picture of the bad or NOT SPOT areas then your ISP will have to act to ensure that you don't move your service to another provider.
If you have the same problem as me then unless you can get Virgin Media Cable that can supply upto 20MB download speeds then BT maximum 8MB speed will be your limit expect to get about 4MB using the BT copper wired pair and your ISP's own router if you live over 5 miles from the exchange.
on Jan 05, 2010 | Computers & Internet
Am not able to download/install oovoo on my laptop.Is it because my laptop is hp ?
Version for Windows System Requirements:
bullet.png Pentium 4 1Ghz with 256MB of RAM bullet.png 20MB Hard disk space bullet.png Webcam and Headset bullet.png Broadband connection (Cable, DSL etc..) bullet.png Microsoft Windows 2000, XP, Vista or WIN 7 compwin7.png Version for Windows System Requirements:
bullet.png Pentium 4 1Ghz with 256MB of RAM bullet.png 20MB Hard disk space bullet.png Webcam and Headset bullet.png Broadband connection (Cable, DSL etc..) bullet.png Microsoft Windows 2000, XP, Vista or WIN 7 compwin7.png here are the specs. if you meet these try to reinstall or even download again
Apr 24, 2010 | HP Computers & Internet
If I try and download any antivirus software (I've tried Avast, AVG, ZoneAlarm) it takes forever (over 4 hrs) and then I'll get a message saying Server has reset, download failed. Unfortunately I have a...
Try to download smaller antivirus.. On dial up connection, it's common to download application above 20mb such as antivirus for 3 or more hours. Try using free download manager or some download helper that support resume so that you can resume your download if some issues disturb your download :)
Mar 05, 2010 | Microsoft Windows Vista Home Premium...
Slow loading of applications
just trying download this application and select the option a
Jan 30, 2010 | HP Computers & Internet
Mtu Settings for the Thomson ST585v6sl
The MTU is the Maximum Transmission unit. Basically this tells the router how small to break the packets up, that it sends to your computer. When your computer downloads a internet page, it comes to it from the router in pieces. The size of the piece is the MTU. Changing it will NOT speed up your bandwidth from .5 to 3. Whatever bandwidth you get from your provider is what you have. The only thing that your router does, that can slow it down is the security key. If you have the wireless security on, then it has to verify each packet. If you need it leave it on, if not turn it off. If you turn it off, ensure you have other security measures in place.
Nov 25, 2009 | Zhone (6218-I2-200) Router
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
Netgear DG834GT
You will have to set the MTU to 1500, that speed is not enough, if you are getting only 416Kbps downstream, then it's not right, either the router is at fault or your isp, understandably you are on 8mbits but you need to do a line speed check at BT web site and see what you should be getting in theory, as you may be far away from the exchange. The MTU of 1500 may not up it to what is should be, i think you need to check your line filters and get a line check done as 416 mbps is unacceptable.
Jun 18, 2007 | NetGear DG834G Router
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Microsoft Windows XP Home Edition Logo
1,382 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
