How do I get the Toshiba Laptop to boot from a USB?
  • 1 more comment
  • todd_appleto Jul 28, 2009
    The laptop is a Toshiba Satelite L35-S2161
    We tried this but USB is not an option to boot from.
    The model number of this Toshiba Satelite is PSL33U-02401D
    Novelist:
  • 148 Answers
this should be supported in the BIOS that is the setup screen if you want it to happen, enter setup by del or f2 whatever your first screen says to enter setup and change the boot sequence to boot from the USB drive.
Further Queries are welcome
if you think my solution was helpful please do rate me
Posted on Jul 28, 2009
  • bbansiwal Nov 19, 2011
    U tel about it toshiba satalite 2400 s-251 (balveer)
    Novelist:
  • 81 Answers
I could give you a more specific reply if you left your laptop model number. But, if your laptop supports booting USB devices you will need to power down your laptop and connect your USB drive. Once you power on your laptop slowly tap the F12 key (as if you were entering the bios setup) until a menu pops up with boot options. It will be a simple text list that will show your hard drive, cdrom and your USB drive(If supported). If you do not see your USB drive in that list you can try booting off of the removable drive. If none of these options work then please post your model number and I can tell you for sure if USB booting is supported.
  • Brann Fenix
    Brann Fenix Jul 28, 2009
    Yes, that laptop should should support USB booting just fine. You can go to the BIOS and change the boot order BUT remember to change it back or you may have problems booting your main hard drive in the future. The F12 menu just generates a one time boot menu that lets you select which device you want without changing any system settings. This is ideal if you only need to boot your USB device once or twice to perform an update or a repair. If you plan to boot your USB device every time then by all means go into the BIOS setup permanently change your boot order.
  • Brann Fenix
    Make sure you have legacy USB support enable in your bios and try it again. If the option is not there and booting from removable device will not work either you might be out of luck. The info for that laptop model is a little limited, but it is possible that your model does not support this. I just worked with a Toshiba from a friend over the weekend that would not boot off of a USB drive either. Is there a reason you can not boot off of a CD? I understand a USB drive is easier, but sometimes on older machines it is CDs or worse... Be thankful booting off of a floppy is not your only choice :)
My laptop stopped working so I removed Toshiba MK2565GSX hdd and I have a usb to sata/ide adapter connected to the hdd but it wont power on and the motor isn't spinning. I have important videos on their...
ur toshiba hdd is ur laptop's primary hard disk, so it is not booting from external hard disk, so open bios in ur laptop and set booting with usb as primary booting device, it works, if u have more doubts post me again
Aug 06, 2013 | Toshiba MK2565GSX Hard Drive MK2565GSX
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
My toshiba cannot boot through USB. it dispalays "windows missing" yet the flash disk has got a windows xp setup
Your flash drive only has the setup program not the actual OS as it would be on your hard drive.
The fact that it won't boot through your USB is because there is no OS on your laptop with the required drivers for your USB and other hardware, for that.
You need to have OS installed on your hard drive to be able to run all the peripheral hardware, else nothing happens.
Please install the apropriate Operating System (OS) on your hard drive, and voila!!! magic happens after that.
Cheers, Peter
Feb 21, 2013 | Toshiba Satellite A135-S4477 Laptop AC...
No operating system found can't boot from usb there is no boot from usb option
Did you try pressing F8 key at boot up?
  • 1
    Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
  • 2
    Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
  • 3
    Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
  • 4
    As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
  • 5
    Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
  • Read more: How Do I Get My Toshiba to Boot From a USB? ' eHow.com http://www.ehow.com/how_5970005_do-toshiba-boot-usb_.html#ixzz1hrx9qZ3j
    Dec 28, 2011 | Toshiba Computers & Internet
    I HAVE TOSHIBA A45-S151 AND I WANT TO BOOT IT FROM EXTERNAL USB DVDWRITER FOR INSTALLING FRESH WINXP-SP3 FROM DVD BUT IT IS NOT BOOTING BECAUSE MY LAPTOP IS NOT SUPPRT EXTERNEL USB CDROM BOOTING OPTION....
    A BIOS update may still not allow you to boot up from an USB port.
    You can download theBIOS updates and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
    Sep 09, 2011 | Toshiba Satellite A45-S151 Notebook
    Hello! i have a laptop,Toshiba Tecra T9100.The Cd-rom is not working and i whant to reinstall the windows from usb boot-able. in BIOS i cant find nothing like this...to boot from USB! HELP!!!!!!
    press f8 as you on the laptop and you will get the " select boot device " menu. here you can select the usb drive.( keep the drive connected before you on)
    PLS REPLY OR COMMENT. THANKS
    May 16, 2011 | Toshiba Tecra 9100 Laptops
    I want to boot my toshiba sa50-543 laptop from pen drive
    While starting system U will find message on task bar that press F2 to boot.Then press F2 while starting the system.U will find blue screen in DOS mode stating boot order.Select boot order as USB insted of CD ram driver.Then save by pressing F10.Then insert USB drive to USB port2.0.Automatically it will boot O/S from USB drive
    mohanraojagan@yahoo.com
    Nov 07, 2010 | Toshiba Office Equipment & Supplies
    Toshiba Tecra A3X Not Booting from USB CD ROM
    Your laptop is apparently unable to boot up off an external usb source. Only newer equipment has this provision in the bios. Since you cannot boot up from usb the only way you can recover your unit or do a clean reinstall or repair of xp is to replace the internal drive that is allegedly defective.
    Replacing the optical drive is fairly easy and does not involve massive disassembly of your laptop. And any cheap drive will work provided it has the same physical configuration as the old one.
    Jul 03, 2009 | Toshiba Tecra A3 Notebook
    0701 usb over current on hc/port error
    I had the same problem on a toshiba satellite u400.
    Usb over current on port ... blabla..
    Please press F1 to resume or F12 to install.
    F1 just ended up in a screen asking to press F2 or F12 which did nothing.
    F12 did nothing.
    Rebooting the pc ended in a black screen with a flickering HD symbol.
    To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
    Once It restarted booting on the error USB over current.
    Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
    Don't have any idea why it became faulty but it's now solved for me.
    Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
    Boot from usb
    Sounds like the boot order menu is what you have. Set the boot order menu to try other devices before the hard drive. (Example: CD/DVD drive, floppy; if present, USB devices, hard drive). You should have a default key for accessing the boot menu (usually f11 or f12). Hit this key and choose the USB option. Make sure the device you want to boot to is already connected before you turn on the laptop.
    Mar 01, 2009 | Toshiba Satellite A60 Notebook
    Computers & Internet Logo
    780 people viewed this question
    David Payne
    David Payne
