Question about Refrigerators
Kenmore bottom freezer ,back of the
Kenmore bottom freezer ,back of the freezer gets very frosty
    Champion:
  • 363 Answers
Replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Posted on Jul 30, 2009
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to...
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Kelly
Mar 24, 2011 | Kenmore Side by Side Refrigerator
Refrigerator not cooling, freezer is working
check the vent from the fridge to the freezer. is any air blowing through it? if not, check the back wall of the freezer for frost. if it's frosty, you have an iced up evaporator coil. either the fan is not blowing or the door seals are bad.
Dec 17, 2009 | Kenmore Refrigerators
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator works, freezer doesn't
The part that is usually the issue on this model is the defrost thermostat.
I usually test it for continuity while its frosty with an ohm meter. If you don't have an volt/ohm meter, you can get a cheap one at Radio Shack.
It clips on the top right side of your evaporator coil. It is part 23 on the diagram at this website http://content.searspartsdirect.com/lis_png/PLDM/P0070077-00003.png
Let me know if you need anything else
Benjamin
Apr 26, 2009 | Refrigerators
My refige is warm and my freezer is frosty
lg american fridge freezer my fridge is working ok but my freezer isnt can u help please ty
Dec 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Warm fridge frosty freezer
Hi. thanks for the question . check the freezer fan motor, is it running . is there frost build up in freezer, check that. pull fridge away from wall. remove back panel .clean all lint . thanks the appliance doc
Sep 17, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore side by side refrigerator problem
not common you have a defrosting problem, a defrost heater, or a defrost bi metal or defrost timer problem
Apr 12, 2008 | Refrigerators
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
