Question about Dewalt Chop Saw D28700
Dewalt chop saw blows breaker after a few minutes of use. Bearings bushes and armature ae good. Is the gear box dragging so much that it powers off and blows the circuit breaker? Where in San Antonio, Texas can I have it fixed or where can I locate parts to it? Thanks, Romeo Herrera romeoherrera@sbcglobal.net
  • 520 Answers
You can register with Dewalt ServiceNet(www.dewaltservicenet.com) and order parts direct on-line. In San Antonio Tx there is a local source located at 500 Culebra Ave San Antonio Tx 78201 ph#210-732-1221. The service net also provide exploded parts view of your machine which is very helpfull.You may have warranty an this machine in the event of any factory defect associated with this machine which can be determined on the service net....good luck
Posted on Jul 28, 2009
Dewalt dw 718 type1 making noise like electric brake is stuck on
There's a good chance one or more bearings have failed. There are 2 on the armature plus more in the gears and spindle assemblies. The saw will need to be disassembled to check the condition of the bearings.
Jun 06, 2014 | Saws
Mitre saw blows breaker
bad cord, switch wired wrong, or bad motor. Pull the cover off the motor. Disconect the power. Sping the balde by hand and look at the bars on the comm, end of the armature. They should be evenly colored and the spacing between them should be even and clean cut looking. If there is heavy discoloration on one or two bars or heavy pitting between a couple bars the armature is likely bad.
Jan 02, 2014 | Dewalt DW715 Heavy Duty 12" Single -...
Dw716 sounds funny
The brushes should not make any sound. It sounds like it could be the armature bearing.
Mar 03, 2013 | Dewalt DW716 12 inch Double-Bevel Compound...
10'' delta mitre saw making bad noise when in use
Highly unlikely the armature would warp. Both front and rear armature bearings would be my first guess.
Jul 10, 2012 | Delta Chop Saw 3 Ph, 50/60 Hz,...
Armature is shorting out, throwing sparks out rear cap/ has new brushes (thought that was problem / shows small burnt area on armature / i cannot figure out how to remove armature / I stripped saw down to...
you have to pull on it to remove it or
use a punch and hammer on the end of armature(gear side)be careful to not damage teeth if you want to reuse it
Oct 03, 2010 | Dewalt Chop Saw D28700
6180-20 chop saw trips 20 amp on start up all the time Terry
If it trips the breaker as soon as you hit the switch, check the power circuit. Check the power cord for frays or cuts, especially where the cord goes into the saw. Remove/split the handle and check the wires into and out of the switch and to the brushes and field. Lood for burned or melted wires or case parts. Milwaukee is notorious for running lots of small wires in very tight places. Make sure none of them got pinched when the tool was assembled. Watch for this also when you reassemble the saw. Check the brushes, if they're worn or broke they can cause a short on the armature. If these all check out you need to have the armature checked on a growler for shorts.
If the saw runs for a few seconds then trips the breaker I'd check for gear and bearing problems. Cehck for free, smooth movement of the bearings on the armature and blade drive assembly. The blade should turn freely by hand. Feel for undue resistance or a gritty feel in the bearings and gears. If necessary replace any offending parts.
Aug 31, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
My dewalt dw 402 grinder, starts fine, runs for a few minutes and then shuts down. Brushes appear to be fine.
Pull it apart and clean the armature, you will find something between the brush contacts getting larger and making contact thus shorting it out, so clean the armature with fine point object do not gouge the material out of the area between the copper plates. Also blow out any metal dust you may see.
Jul 31, 2009 | Dewalt Small Angle Grinder 4 1/2"
Metal chop saw blows breaker
Is there anything else running while you are cutting? If not is the breaker 15 amp or 20 amp. If its 15 amp, I would change it to a 20 amp breaker. Make sure the wires are thick enough to handle the extra load. If this isn't the problem check the cord from the saw to the outlet.
Good luck!!
Jul 28, 2009 | Dewalt Chop Saw D28700
My Dewalt chopsaw is loosing power and sparks heavy in brushes
I worked at a tool rental center while attending college and learned to repair tools such as yours. Damage to the armature occurs mostly during low power situations or overloading the motor. The damage is usually visable. Notice burned looking copper windings or commutator bars. You can test with growler or meter. We would turn the commutator on an armature lathe to true the surface of the bars. If the commutator is not perfectly round the brushes will bounce thus cause the sparking that you see. Also you must clean the groves between the bars with a blade to clean out all metal filings that can cause short between bars. (Broken hacksaw blade ground to fit the groves will work fine)Sanding with sandpaper may not be perfect enough to stop sparking assuming the armature is not shorted. Moisture will not effect the brushes, and sanding them square is ok but you can put the curve back by cutting fine sandpaper into strip and wraping it around commutator and insert brush into holder against sandpaper. Not necessary thou because all new brushes are square. New brushes however will increase the tension of the brush against the commutator preventing bounce due to new spring and longer carbon. Good luck enjoy
Dec 15, 2008 | Dewalt Chop Saw D28700
Dewalt Chop Saw D28700 Logo
328 people viewed this question
Top Dewalt Welding Tools Experts
Bill Boyd
Are you a Dewalt Welding Tool Expert? Answer questions, earn points and help others
