Question about HTC Touch Cell Phone (Unlocked) - Soft Black
My HTC Touch Diamond Pro touch screen stopped working
I can use all of the buttons and the keyboard but the screen stopped working.
-I tried powering off and back on, taking the battery out, replacing the battery and fully charging it
-I didn't drop it or get it wet
-Sometimes problems like this occurred with my old HTC Diamond Touch when I turned it on in areas of low signal, but I have had full bars everywhere I go.
-The screen appears fine, unscratched and nothing is unusual but it will not respond to stylus or finger touch. (or any touch whatsoever.)
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
I HAVE A HTC TOUCH DIAMOND. WHEN I TURN IT ON IT DOES NOT START UP IN PHONE MODE. THE SCREEN COMES UP WITH A RED,GREEN,BLUE AND WHITE BANDED SCREEN WITH DIAM130 64M SPL-1.38.0000 MICROP-DIAM (LED) V11 IN...
Looks like you should try to Hard Reset it.
This is done by having your HTC Diamond turned off first.
Then, hold the VOLUME UP and DOWN buttons at the same time and briefly press the POWER BUTTON.
Now keep holding down the VOLUME UP and DOWN buttons until you see a screen
At soon as you see this screen, you should release the VOLUME UP and DOWN buttons.
Now press the VOLUME UP button to complete the hard reset. Now this will completely format your HTC Touch Diamond as if it was turned on for the first time from the box. Everything once previously on the phone will be deleted including messages, contacts, music and the like. Hope I have been of assistance to you, Cheers :)
Apr 23, 2010 | HTC Touch Diamond Smartphone
Trying to get screen to turn when texting HTC touch diamond
Unfortunately the gyro in the HTC diamond only operates in certain programs like opera mobile internet browser, when viewing pictures in album, and the game teeter. The keyboard would be bigger if it could be rotated using the gyro but HTC did not program it to do this. There are some free program you can download that will allow you to do this but they also rotate everything else every time you tilt the phone.
Dec 28, 2009 | HTC Touch Diamond Smartphone
The touch pad of HTC Touch responds intermittently.
hi, its a error in the phone, I had this happen to mine. You will most likely have to sent it away for repair. Just reflash the stock ROM and make sure that you have reflashed the stock SPL if you where using hard SPL and you will be ok this site will help you flash: http://lievenvw.wordpress.com/2008/09/18/howto-flash-your-htc-diamond-or-htc-touch-pro-with-a-custom-rom/ thank you
vijay
(vote for me)
Sep 23, 2009 | HTC Touch P3450 Smartphone
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Touch screen will not respond
try hardreset, if it does not help, you could have broken digitizer, put it to service, manual replacing is very difficult
Jul 03, 2009 | HTC Touch Diamond Smartphone
Hi my htc touch pro keyboard stopped working and i didnt drop it or anything what may be the problem??
either you pushed too hard and maybe broke the buttons or sensors in the screen. youll probly have to either get the screen replaced or buy a new phone
Jul 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
My HTC Diamond Touch Screen wont work
you can try to recalibrate the touch screen to see if that works,
Start> settings> display> calibrate
* since screen is not working you will have to go the long away and use buttons on phone and nav wheel to get to these options
Jun 17, 2009 | HTC Touch Diamond Smartphone
Htc Touch pro keyboard stopped working. Also stuck in landscape
i had the same problem. if you take it in to the store you can get it reset to factory settings. it helps if you have insurance.
Apr 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
778 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
