Question about Zebra TLP 2844-Z Thermal Label Printer
Send a .txt file (zpl language to COM1) to theTLP 2824-Z.
Hi.
I try to send a .txt file (with zpl language, to COM1) to the TLP 2824-Z, with DOS-command:
"TYPE pp.txt > COM1"
All is OK, but if I send too much labels, it doesn't work fine - lost records, jumps between labels, etc. -.
Somebody can help me, pls?
Thanks
Help!!! I can not print barcode with DOS-command "copy barcode.txt com1". DOS Version is 6.1.7600. The printer zebra TLP 2844 does not recognize the EPL commands.
j.zh
Posted on Mar 21, 2011
    Problem Solver:
  • 12 Answers
What version of DOS are you using?
Posted on Jul 28, 2009
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
Good day, We are currently using a Zebra 2746E, that needs to be replaced, the problem is we have a huge amount of labels designed in Create A Label, is there a way to use a new Zebra S4M with the...
the language from your printers is EPL and the zebra S4m come from factory with ZPL language program, you need to install diferent firmware to the printer,
"...This firmware release includes all features of the previous V4.49 release. It is for use with
the following EPL printer models:
• TLP 2746e..."
Special Firmware Version Size E53.17.3 3 MB
http://www.zebra.com/id/products/global/en/firmware/barcode/e53_17_3.NotesFile1.File.tmp/14328L-006.pdf
download the firmware, go to the driver and "send file" and send the file *.zpl to the printer.
Nov 22, 2010 | Zebra Create-A-Label 3 (105580-001) for PC
My Zebra 105SL printer is printing very slow. How do I upload my Caret file to this printer?
Caret file? Do you mean zpl, the actual label to be printed? If so you can access that from the web interface, just point your browser to the printers ip and follow the menu's. If it's not on a network you can use a command prompt the "type" the message to the com port. Just create a text file with the zpl and save it, then in a command prompt browse to the directory that contains the zpl and issue the command "type zpl.txt > com1" or whatever com it's on.
Jun 17, 2010 | Zebra 105SL Thermal Label Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Thermal Label length problem
how are you sending the data to the printer and what type of media are you using? you can set the page hight via the ZPL command ^LL ,the value you send with ^LL is in dot, so if I wanted to set the label hight to 10cm I would send ^LL800. Or if you are printing via a windows driver configure the printer to continues media.
Nov 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2824 Sebra
is the printer an EPL or ZPL model? i will need to see a hex dump of what you are sending to the printer to pin point the error but it sounds like a label layout issue.
is the barcode content the same on each label? if the barcode content is changing the barcode will grow and move to the right.
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
3,030 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
