Question about Saeco Odea Giro Plus Coffee Maker
We haven't used our Saeco Talea Giro coffee machine for 6 weeks. The first time we came to use it today, the beans were ground, but no coffee came out the spout, although water did come out the water spout. We have checked all the settings and everything is as it always has been. can you suggest anything please?
    President:
  • 1,618 Answers
Check the screen in the brew unit, it might need to be cleaned.
Posted on Jul 29, 2009
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: I have a saeco Talea Giro machine. When I press
Check the screen on the brew unit, it might be blocked. If the brew unit is cleaned and the problem is still happening then the steam valve needs to be rebuilt because the pins are allowing the water pressure to pass through.
Posted on Oct 07, 2009
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
I have a Talea Giro and the red alarm light keeps flashing. I have refilled water and coffee and cleaned the brewer. Sometimes it will work after turning off and on again. Sometimes heats up and is ready...
Checklist:
  • Water tank full
  • Remove dregdraw for at least 10 seconds then re-insert
  • Beans in hopper
  • Beans lid correctly inserted
  • Steam knob Exactly in off position
Feb 25, 2010 | Saeco Talea Giro Espresso Maker -...
Talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
Grinder is not functioning, apparently, resultant brew is between tan and clear.
HOw oily are the beans you are using ? cause oily beans will clogg up the grinder causing none or little to come out. Try running some really dry beans threw decaf beans are generally drier than most. If the amount of coffeee being ground doesnt increase then the grinder will have to be taken apart and cleaned out.
Dec 17, 2009 | Saeco Talea Giro Espresso Machine
How do I remove the drip tray on the Saeco Talea Giro?
I have a Talea Giro. To remove the drip tray, just pull it off. I pull from the centre
Nov 09, 2009 | Saeco Talea Giro Espresso Machine
I have a saeco Talea Giro machine. When I press the button to make coffee, the beans grind but no coffee comes out, but raher the water comes out of the steam spout. What is the solution
Oct 07, 2009 | Saeco Talea Giro Espresso Maker -...
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
297 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
