I have a GE WPSR3100W0WW that makes a loud, constant noise when on spin. My guess is this is the tub bearing, but it's not clear to me from the parts guide online which part is making the noise -- the 'bearing' PS271509,or the 'hub' PS273296. Is there a kit for this repair that contains all likely-to-be-needed parts (e.g. - a new seal)? Or, can you tell me which parts to order?
Thanks,
Andy
SOURCE: main seal
This is a pretty tough job to do on your own, but can be done. First step is to remove the front, then the top. Remove the rear cover plate under the console, and swing it out of the way. Unclip the top ring and remove the four suspension dampener straps, remove the top ring. Reach under the agitator, and pull up with force (dont hit yourself in the head or face with it, hurts for sure...) until it pops off (agitators on GE's just snap). Sometimes these can be a real bear to get off, so dont get discouraged. Sometimes you can put a peice of small rope or line under it and jerk it up. After you remove the agitator, you will see the drive bell. Remove the bolt on top of the bell, and once again, try to pull the bell up and off the shaft (once again, a real bear in some occasions, rope trick or puller also will work here). Once you remove the bell, the good part starts. Most of us repair persons have a special spanner tool for that nut your looking at. I believe it is a 1 7/8" nut. This nut is REVERSED THREADED, which means to remove you will spin it clockwise. These spanner nuts can be very, VERY difficult to remove. A lot of WD-40 and time. Most of the time you have to bang them off with that special tool and a hammer, but you may get lucky. If you do get that nut off, you can remove the inner tub. Be sure that the metal drive hub bolted to the bottom of the inner tub is completely tight all the way around. GE units have a very bad habit of those screws backing out and the drum getting loose causing major league noise. Now that you have removed that, you need to remove the outer drum. Remove the wires from the motor, etc. Unhook the 4 suspension rods and plastic clips by pulling the bottoms down (spring loaded) and removing them from the frame. Unhook the tub to pump drain hose, tilt the entire center section top towards the back, and swing the unit out from the bottom. Remove the outer tub by removing the hold down screws. Your seal will be in the bottom. Just pop out and replace. Here are some diagrams that might help you out.
Cabinet and Top:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET%2C%20COVER%20%26%20FRONT%20PANEL&titleID=00002&
Drum, Agitator, Basket:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20BASKET%20%26%20AGITATOR&titleID=00003&
Drive Componants, Suspension Parts:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=SUSPENSION%2C%20PUMP%20%26%20DRIVE%20COMPONENTS&titleID=00004&
Good luck, and let me know how it comes out, or if you need anything further. Good Luck!!!!!!
SOURCE: Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
SOURCE: GE Washer WPSR3100W0WW roars like a freight train in spin cycle
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
SOURCE: Worn out drum bearing and seal
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Hi
If its rattling check the drum for anything
caught in it.Washing machine noise is not only annoying, it can also be a sign
of serious damage. When armed with a few tips, you can determine what problem
may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin
cycle. Drum bearing failure is common when the bearing seals start allowing water
to enter. You can take the belt off and spin the drum by hand, and if the drum
rumbles, replace the bearings.
Turn the drum by hand and listen for loud
noises. If the drum itself is split or the 'spider' is corroded, broken or has
come apart from the back of the drum it will create a loud noise on every turn
of the drum. (When the bearings have gone bad, the noise is constant the entire
time the drum is spinning.)
Look for obvious dents and creases in the
drum or look for coins or small objects stuck inside the tub underneath the
drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like
coins or small objects when a noise occurs while the washing machine is
emptying water.
Remove the sump hose and look for bra wires
if you hear a light scraping noise when the drum is turned by hand. You can
also check to make sure a wire isn't poking out of one of the holes in the
drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if
you hear a high pitched squealing noise to check for motor bearing damage or
wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
