Question about Craftsman 22" Gas Hedge Trimmer
Needs new fuel lines
The fuel lines come off and leak.
Fuel line leak
No, Fuel line leaks cannot be repaired and need to be replaced with a new line. ----------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 09, 2013 | Cars & Trucks
Fuel line coming off fuel pump is leaking
you have to buy new fuel pump with new fuel line in place if you are talking about the in tank fuel pump.
Feb 17, 2013 | Cars & Trucks
There is a leak around the 2 tubes from the fuel bottle when the machine is being filled or held with the fuel bottle in an upright position. Remedy please
Hi donhodgson1...
Those two fuel hoses need to be replaced with new fuel lines.
When fuel lines get old, the tend to get hard and will be subject to leaking fuel.
Be sure to mark which fuel line went where...
Please take time to rate me
Jun 20, 2011 | Homelite Garden
I have a hole in my gas line up by where it goes into the injectors in my 97 intrepid.how and what do i need to do to repair or replace it?
YOU NEED TO REPLACE THE FUEL LINE.YOU NEED TO RELIEF FUEL PRESSURE FIRST.BUT THE LEAK WILL BLEED OFF FUEL PRESSURE.ALL YOU HAVE TO DISCONNECT REMOVE THE LEAKING FUEL LINE AND INSTALL THE NEW FUEL LINE.
Nov 27, 2010 | 1997 Dodge Intrepid
2002 yukon hard to start, where is the fuel filter and how to replace it.
FIRST RELIEF FUEL PRESSURE BY REMOVING GAS CAP REMOVE FUEL PUMP RELAY START ENGINE UNTIL IT DIES LACK OF FUEL. FUEL FILTER IS MOUNTED TO THE RIGHT FRAME RAIL.NEAR THE FUEL TANK.YOU NEED A FLARE NUT WRENCH TO LOOSEN FUEL LINE AT FILTER AND A ADJUSTABLE WRENCH HOLD FILTER LARGE NUT WHILE LOOSEN FUEL LINE THIS KEEP FROM TWISTING FUEL LINES WHILE LOOSEN FUEL LINE.BESURE TO GO TO DEALERSHIP AND BUY NEW O - RINGS AT FUEL FILTER LINES.LUBRICATE NEW O- RINGS WITH CLEAN ENGINE OIL.WHEN INSTALLING NEW FUEL FILTER DONT OVER TIGHTEN FUEL LINES CUTTINGTHE O -RINGS AT FUEL FILTER.IF SO THEY WILL LEAK GAS WHEN YOU START UP ENGINE.WHEN DONE CHECK FOR GAS LEAKS WHEN DONE DONT DRIVE UNTIL YOU CHECK FOR LEAKS FIRST.
Aug 16, 2010 | 2002 GMC Yukon XL
Strong gas odor
  1. The fuel lines may have a leak: Replace leaking fuel lines and/or fuel line fittings.
  2. The engine may have mechanical problems: Check vacuum lines and fittings for leaks. Check engine compression. Check for broken fittings and mounts.
  3. The fuel pressure regulator may be operating at too high a pressure: Perform fuel pressure test and repair or replace faulty component(s).
  4. The ignition timing may be set wrong: Check and adjust ignition timing.
  5. The fuel injectors may leak: Clean or replace fuel injectors.
Sep 15, 2009 | 1996 Ford Explorer
Fuel line leak
Best to replace the whole rubber hose.
Jun 02, 2009 | 1990 Plymouth Voyager
Placement of O-ring in fuel line to pump assembly 1998 Astro
Was it a clean new o ring? If not get a new one for used ones will leak. Yes they simply slip onto the outer lip of the pressed line too
May 25, 2009 | 1996 Chevrolet Astro
89 Chevy Beretta Fuel Lines
how do you know it needs fuel lines, are they leaking? is fuel pump good?did you do fuel pressure test? did you chk. to see if filter is pluged? just because the tank leaks won't keep it from running and that can be fix with a little apoxey and a some elbo grease.
Feb 02, 2009 | 1989 Chevrolet Beretta
1993 Dodge Caravan
I had exactly the same problem after I changed the fuel filter. Tried new clamps and tightening them etc. Nothing worked until I purchased a foot long hose from a auto store for couple bucks and replaced the both ends with the new hoses. Old hose hardens over time and it doesn't seal well after it has been reused.
Jun 19, 2008 | 1993 Dodge Caravan
Craftsman 22" Gas Hedge Trimmer Logo
62 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
