Lands Phones Logo
A
Art Raby Posted on Sep 07, 2017
Installed new battery in GE 27923GE1-A cordless phone. Can't get a dial tone.
5 Related Answers
Anonymous
  • 131 Answers
  • Posted on Sep 30, 2007
SOURCE: ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Anonymous
  • Posted on Jan 27, 2008
SOURCE: GE 5.8 ghz cordless phone
My GE cordless phone , as well as my other phone , which are uniden cordless phone have lost their dial tones. I'm trying to reset my uniden phones by unplugging the bases and unplugging the batteries from the phones and wait for about 30 min. , then hook them back up and reset them to the bases again , they think that will work for the Uniden phones, but my GE phone doesn't have a reset program on the menu , do you have any other suggestions. Also I have a regular phone in my home and they are working properly , just my cordless phones are out.
Anonymous
  • 555 Answers
  • Posted on May 21, 2008
SOURCE: GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
Anonymous
  • 76 Answers
  • Posted on Dec 02, 2008
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Tom Torre
  • 279 Answers
  • Posted on Sep 19, 2009
SOURCE: no dial tone/ cordless phone says "searching"
Go to http://www.home-electronics.net/ge/pc/user-manuals.asp They have the manual there
How do i change the telephon for pulse to tone??
With the handset idle, press the PROG button until you hear a beep, press the TONE button, press the PROG button again, the phone will beep to confirm. I have included a link where you can download the manual for your phone.
http://www.home-electronics.net/USER-GUIDES/27923_DOM_ES_CL_IB.pdf
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
3answers
2helpful
2answers
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
6helpful
4answers
Ge 900 MHz cordless phone set on rotary dialing
7answers
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
