Question about Dryers
Where to get florescent ballast feh382d/6/120
4 Suggested Answers
  • 74 Answers
SOURCE: How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Posted on Jan 18, 2006
  • 3 Answers
SOURCE: How do you replace starter/ballast in countertop
Yes, probably you'll need special help for that, or simply take off your countertops
Posted on Aug 04, 2010
  • 27 Answers
SOURCE: The backlight ballast not working
Change inverter board
Posted on Dec 09, 2013
What is a ballast?
A ballast keeps a tiny charge running into devices that would otherwise need to "warm up" in order to function properly. Non-flicker florescent lights use a ballast so that they come on right away when you flick the switch.
Oct 29, 2014 | Televison & Video
Someone told me to replace something called ''ballast'', what's that?
a ballast is like a transformer, as an example, florescent lights require one between the power supply and the tube.
Jan 20, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
My 4ft fluorescent fixture has whiye and black wires that have been connected, hot and nuetral but it also has a red (brown) wire ? where does this go.
They make dimmable ballasts.
The Lutron dimming ballast shows an orange wire, not a brown >> but other manufacturers might call for different color.
I am guessing here, but ballast should work with Black Hot and White Neutral
I want you to answer back and say if the ballast works with just white and black, Thank you.
Here is a 3-way dimmer to control florescent ballast
Oct 18, 2010 | Lithonia Lighting Lithonia Ps300...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
The labtop screen is not lighting up I had it checked by A technician and he said the video is gone however it is made up to the mother board is this correct
no , that can't happen: your screen has tiny florescent tubes and, a ballast to light up the screen replace the ballast it is located in the bottom middle of the screen frame between the hinges; ebay sells the part.
Jun 24, 2010 | Computers & Internet
I HAVE AN AUDIOVOX LCD WITH SOUND BUT NO PICTURE.HOW DO I FIX IT .WHEN I TRY TO GET INTO THE MENU I CANT SEE ANYTHING
I strongly believe that one of two things has happened:
1) the back light 'florescent tubes' lamp ballast power supply board has gone out.
2) One of the florescent tubes has failed taking out the lamp ballast.
Is the TV still under it's factory warranty?
If it is not I would call around some TV service providers in your area and get some estimates of repair. Fairly common item to go out.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Vizio television screen flickers like a strobe light
lcd sets use florescent tubes to light the display and, a ballast to power the tubes just like the lights in an office ceiling.
the tubes are called cold cathodes and, the ballasts are called inverter boards. replace your inverter circuit board it connects by wires to the cold cathodes so; isn't hard to find.
Oct 05, 2009 | Vizio GV42L 42 in. LCD Television
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Dryers Logo
738 people viewed this question
Top Dryers Experts
