Question about Hoover Vacuums
Hoover SpinScrub 50 wheels won't spin - Hoover Vacuums
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
The bearings in the turbine are prone to seizing because of moisture. Take it to your local vacuum repair shop and have them repair it. At my shop we re-grease the bearings and it's better than new. If there is too much damage the turbine will need to be replaced
Posted on Sep 07, 2017
SOURCE: hoover spinscrub
First do they turn easily by hand? Usually there is a plastic shaft that drives these brushes. If they are "seated" properly, the unit will not turn. The shaft is usually a "male" and fits into a "female" opening. If it is installing correctly, then I would see if any belts are off.
Posted on Jan 17, 2008
  • 240 Answers
SOURCE: were can i find the
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Posted on Jun 22, 2011
SOURCE: my brushes dont spin on my Hoover SteamVac
ensure that the selector button is in the appropriate spot for aggitation.
Posted on Oct 26, 2011
CorvetteKing
  • 108 Answers
SOURCE: The brushes on my Hoover Steamvac Widepath LS SpinScrub model # F6040 900 are not spinning. What should I do to get the brushes spinning again?
On those models the brushes are turned by suction.
1. Check the lower tank to be sure its completely closed and sealed.
2. Check the lower tank to be sure the tools filler plate is in place (if you used the tools recently)
3. If both 1&2 ok, manually turn the brushes, if they do not turn freely you may have a stuck turbine or bad brush block.
4. Take the brush block out by releasing the tabs on each corner being careful not to break them.
5. Place a large flat blade screwdriver in the square drive hole that drives the brushes under the machine. Gently turn. It should turn slowly with some resistance. If it turns slowly it is ok. If it turns with no resistance it may be bad as well. If it will not you may be able to break it loose with some even pressure being careful not to strip the hole. If it will not turn or makes a lot of noise replace the Turbine assembly.
6. If the brush block has a broken drive shaft or will not turn replace the brush block.
Here is what that brush block should look like.
http://www.vacuummedic.com/product.php?id=206
Good Luck!
Posted on Aug 21, 2012
  • 187 Answers
SOURCE: Hoover spinscrub 50 won't power on
It's Done! You need a new motor, So you need a New Vacuum!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Posted on Jan 20, 2014
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
The brushes on my hoover model f7412900 quit spinning.
Could be just jammed up or the turbine wheel has cracked (common problem) here is the link to buy new one. Good luck.
http://www.vacpartswarehouse.com/ProductDetails.asp?ProductCode=43191018
Jun 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
MY VAC WONT START
check on /off switch, wiring, and motor. please be safe.
Nov 15, 2013 | Hoover SteamVac Spinscrub 50 Carpet...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Wheel in Hoover SpinSrub turbine broke
Sorry, you will not find that one part available for sale. You will need the assembly from the manufacturer, or may check online sales/auctions.
Nov 20, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
391 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
