Question about GE Refrigerators
My refridge isnt cold enough but my freezer isthe fan sounds like its running and the condenser is on. also the fan/condenser are never turning off by them self
  • 24 Answers
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Posted on Jul 28, 2009
Freezer fan only run sometimes
If you nudged the fan and it started working it could be defective and needs to be replaced or it could be freezing up because of freezing condensation. Be sure that all the coils under and behind the fridge, if there are any,
are free from dirt and dust. If this is a refridg/freezer be sure the air vent between them, on the inside, is not blocked by anything. The airflow is necessary for proper temp control.
Apr 20, 2014 | Whirlpool Washing Machines
Fridge compartment is not cold enough
inside the back of your freezer there are two holes that lead to your refrige there is also a fan with a small motor attached is the fan blowing the air fromthe freezer into the refridge section also are the two holes plugged up with ice these are some of the first things that you should be checking turning that switch basicly jut opens the damper door that goes fromthe freezer to the fridge so in allactuality if the door is pluged with ice or the air isnt being pushed through those holes your refridge wont get that cold also another thing to check would be the operation of that small damper door if you do have a fan runnning and do not have ice but if the door is always closed this could also cause this problem hope this helps
Jul 16, 2010 | Hoover HDA452 Top Freezer Refrigerator
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Maytag bottom freezer. Freezer cold, refridge. not cold. De-iced freezer. Why does this continue to happen?
Sounds like your Freezer Fan is wearing out. When this happens it is very hard to diagnose. The reason is that the fan is turning, but at far less rpm's then iss necessary to keep the air circulating thru the freezer and refrigerator. Then minimum cost to repair/replace this fan is $300.00. But this will releave the problem.
Jul 28, 2009 | Refrigerators
Refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
Jul 07, 2009 | Refrigerators
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
