Question about HP PSC 2510 All-In-One InkJet Printer
Hp 2510 will not turn on
When I apply power the display turns on showing an hour glass. After about 5 secs there is a small clicking sound in the speaker and then the displays turns of for a few secs. After that the process repeats infinitely.
This happened after a power outage in my area. Any help will be greatly appreciated.
  • 3 Answers
I, too, have this same problem. My printer is about 5 years old. Do you think it could just be dirt?
A few months back it was doing the same thing, and miraculously began to function properly again. Then, I unplugged it and moved it to another room. Now it is doing the clicking thing again. It seems to be coming somewhere just above the printer cartridges when I lift up the cover.
Posted on Sep 15, 2009
Same problem here. On/off, semi- and full reset didn't work. Tried the "Best Solution" (the ketchup bottle one) here: http://www.fixya.com/support/t218104-making_funny_clicking_noise_hour_glass
Voila! It worked!
The printer is old, and planned obsolescence is kicking in. Won't last long.
Good luck.
Posted on Sep 30, 2009
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
until 2010 when LED BACKLAMPS HIT THE STREETS
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
I have a hp psc 2510 photosmart and my lightbar is stuck
try to turn off the printer, remove cables and then press and hold power button for 5 secs. Reinsert cables and turn on the printer. If the lightbar is stuck, it could be the LEd light itself or maybe the machine. Call hp if symptom persist..
Nov 20, 2010 | HP PSC Photosmart 2355 All-in-One Printer
How t0 clear paper jam from Samsung 3750 printer
Power off your printer for 5 minutes and take a look if there´s not obstruction on inside.
disconnect the printers from the computer or network turn on an hold the power bottom for 30 sec
Aug 15, 2010 | Samsung ML-2510 Laser Printer
Oven Door panel is showing LOC position but can be opened and closed so not locked. Unable to use oven for cooking
What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
Mar 18, 2010 | Kitchen Ranges
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Hp 2510 printer will reset, i have the hr glass showing
Can not find permanent fix, but with my 2510 if I unplug it for about 1/2 - 1 hour it starts properly.
Until the next power shortage of course, than I have to repeat the process
Jun 29, 2009 | HP PSC 2510 All-In-One InkJet Printer
My navigon 2110 wont turn on
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will likely lose any settings and addresses, but better that than no GPS unit.
May 10, 2009 | Navigon 2110 Series Satellie GPS Receiver
HP 2510 printer in "wait" mode indefinitely
It sounds to me like the printer needs repaired/replaced as the gears which drive the printer cartridges' belt are no longer aligning correctly. At today's prices, I strongly suggest just replacing the printer as you can get a new one pretty cheap now. Good luck!
Apr 18, 2009 | Office Equipment & Supplies
On light won't stop blinking and on the display there is an hour glass
there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2510 All-In-One InkJet Printer Logo
601 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
