Question about Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer the control lock light on won't allow dryer
To work how do I reset
  • 5,911 Answers
The following link explains how to correct a Control Lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these procedures do not correct the error, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
Posted on Jul 28, 2009
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Dryer Lockout function stuck
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
woobie dog
  • 1273 Answers
SOURCE: whirlpool duet dryer does not start control lock light is on
Try pause-cancel-pause-cancel
SOURCE: control locked light is lit not allowing any operation of the dry
Did you try unlocking it by pressing on the "End of cycle" button for 3 seconds.
If that doesn't solve the issue, it might be the control board (user interface) might have gone bad.
I had the same issue with my GEW9250 and I had followed these steps to repair the board. I am not sure if it works for you, but you can try it out.
Open the User interface control board
Then remove the PCBS (the green control boards)
Check the led bulbs, for me one of them is fried. You can use volt meter to test it.
Remove the bulb(s) that are fried (not working)
That should fix it...
Posted on Jul 31, 2010
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer duet... the control lock light is on and the dryer won't work
this is the car and truck section - you may want to repost this in the dryer section
Aug 28, 2012 | Cars & Trucks
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer that indicates the "Control [is] Locked. The problem somehow began while I was away over the weekend and it no longer allows me to start the dryer. (I have a total of...
Hello
Your whirlpool duet dryer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
Aug 05, 2009 | Whirlpool GEW9250 Electric Dryer
Duet sport dryer control lock out on
stop coumting and just hole till light goes out if still no response try cutting power then hold power button down 10-15 seconds this may drain and remaining power to control and allow it to reset ..still problem probably control issuefront interface where buttons are most likelt
Jul 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
2,282 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
