Garden Logo
J
John stewart Posted on Sep 07, 2017
Where can I get a wiring diagram for a sovereign 400w electric hedge trimmer
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 12, 2009
SOURCE: do you sell spares for sovereign hedge trimmer
try
www.einhell.co.uk
Anonymous
  • 30 Answers
  • Posted on Sep 25, 2010
SOURCE: need sovereign hedge trimmer SHT 26 pull start
The agents for the Sovereign machine that you have aare Einhell.co.uk you can either phone them,(which I had cause to ) or mail them,but the spares are available as they order what you need,or do not have,rgds benji123
A
Anonymous
  • Posted on Jul 12, 2011
SOURCE: I need to know the
2-cycle engines use 40:1 ratio
Electric hedge trimmer no power
check fuse/ wiring connections/and condition of cable if all are okay then send for repair
Black and Decker 22" electric
I do not know of a reset. Most likely you damaged the wire and have to repair that section, or replace the wire.
If really helpful, please rate.
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Need sovereign hedge trimmer SHT 26 pull start
1984 B&D double sided hedge trimer stops and
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
4helpful
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
22" excalibur hedge trimmer has no spark and will not start
remove plug and ground and see if you have spark at electrode.
Sometimes will not fire under compression.
Check that kill switch is not shorted, just remove the wire going to ground and try again.
If not probably bad coil.
Joe
Top Electric Garden Experts
NOEL
NOEL
john h
Are you an Electric Garden Expert? Answer questions, earn points and help others
