Question about Samsung Microwave Ovens
No heating other thing is OK. - Samsung Microwave Ovens
  • akhtarsm_sma Jul 29, 2009
    It's a domestic oven. Make Samsung
    Model MWO CE 1031 LATB/XTL
  • 23 Answers
Is it a commercial unit or domestic.these vary so much if you can give me the model number i can give you a better answer,regards les
Posted on Jul 28, 2009
Timer panael,light fan,,auto off,,every thing ok,,but no heating
I had a problem similar to yours and I thought somehow I had ruined the microwave oven. Try unplugging it for about a minute and then plug it back in. My service tech did this and it worked fine after that. Then he billed me $110.00 for the service call.
Feb 11, 2015 | In Microwave Ovens
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
My GE Profile microwave oven serial # 2160SF01 is not heating up could it be the power and if so how do I reset the power n
Hello there and than you for choosing fixya
Ok normally when the microwave will work but it does not heat up this is a result of a couple of things
First is the door switch if it has failed in sensing that the door is closed it will allow the unit to work but not heat up but this is very uncommon
Next is the high voltage circutry capacitors that do fail things like the megatron and the power inverter would further cause these problems so these are the things that need to be checked and replaced if found to be bad
Now a lot of times if the warranty has not been used you may be able to use it for this but if the warranty is out i would check the prices of the parts before getting them cause sometimes they are just as expensive as the entire unit ok
Hope this is very helpful for you keep me posted if you need help testing any of these parts and i will help you the best i can ok?
Best regards Mike
Feb 01, 2011 | GE Profile Spacemaker Over-the-Range...
MAKES LOUD NOISE DOESNT HEAT
many parts of coz not heating the microwave firts ismagnetron but you cannot try if is ok or not by using a clamp meter or actualtesting,but the ohter parts can be test,but firts thing dont touch by your handany part of microwave.mostly the problem of not heating is HV FUSE with redwire and white like tube,if you open the tube plastic you will see small wireinside if is good or defective, if wire is continue is good,if wire is brokenor split it is defective,but the other parts is not to recomended to test ifyou are no basic idea for testing coz of the high voltage of microwave.otherthan that if the HV FUSE is ok the second common problem of microwave ismagnetron and easy to replace,carefully to remove the part by using a plieswith insulation for your protection in High voltage.
Dec 17, 2010 | Whirlpool MH3185XP Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Whirlpool 3hler5437jq1 dryer blows fuse
that would be a shorted or "bridged" heating element .. thats replaceable by a repairman or someone familiar with electrical things ..
here is where you can order parts and instructions for your dryer
http://3hler5437jq0.theappliancepartswarehouse.com/
here is where you can purchase a service manual if you need more information .. ($10) ...
http://www.manuals-in-pdf.com/index.php?main_page=advanced_search_result&keyword=3hler5437jq1&forward=plist
Nov 27, 2009 | Microwave Ovens
No heat. light ok, noise hasn't changed. I heard a pop
It's most likely the relay for the magnetron malfunctioning. It'll need professional service.
Jun 01, 2009 | Microwave Ovens
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
H98 code on a panasonic microwave
Go back to the manual, and read the whole thing or just look at the Chapters names, and find teh right one, and hopefully that will answer your problems.
I am a myth, a myth surround by spirit and souls.
- Myth12 [ i love blogs]!
Dec 23, 2007 | Panasonic NN-H264 Microwave Oven
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
