Question about Cell Phones
Nokia 1100 not charging from external charger
The phone works perfectly if battery is charged independently from phone - no voltage or continuity from external charge socket to positve internal battery contact... ???
    President:
  • 1,884 Answers
Ther charging circuit seems to be defective or your charger is gone. Try and test the charger elsewhere.
Posted on Jul 28, 2009
Nokia 1108 charging problem
Either the charger is bad or the phone. Use a friends charger with similar pin. If it charges then replace the charger if not then take to phone to Nokia Care as the charging circuit is bad. Or the battery could be bad. How old is it?
Oct 28, 2013 | Nokia 1100
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
Nokia Charging Problem
Hi, this is what you do when your phone refuses to charge..
WHEN YOU'RE HANDSET REFUSE TO CHARGE.
1. Read the battery charging terminal if it is continually. 2. Read the board interface if it continually on the charging interface. 3. Read the charging put on continuity if it is continually. 4. If they are all contacting, still not charging, then you service it by W/H i.e. washing and heating. 5. If not still charging, you trace the charging interface with another board by means of looping.
REMEMBER: The process by which you connect a tinny copper for an external construction, or a unit interface which is known as looping. 6. If it does not charge it them means that the charging IC is bad.
ALTERNATIVELY: You may advice the person to buy a universal charger or desk top charger and extra battery for a better charge.
Feb 21, 2011 | Nokia 6300 Cellular Phone
My 1100 mobile phone showa not charging
There are several reasons, like bad battery, bad charging connector, bad charger, charging pin problem, charging ic, etc..
You need to try with another charger and with another battery. If changing the charger and battery don't help, follow the instructions below;
First, remove the battery, clean the contact points on the battery and also clean the battery interfaces on the mobile. You also need to check the charging connector and clean whatever is possible. Use soft brush or cotton with Ipa solution or alcohol/spirit/acetone to clean all the metal contacts. Try charging again.
If the above method don't help, you need to change the charging pin;
Still the problem persists, then check the charging ic. Perhaps jumpering will be necessary.
If you are not sure what you gonna do with ic, I don't recommend to play around with it, rather take it to a mobile repairing shop or nokia service center and get it fixed. You may damage another components.
I wish you good luck.
Thanks for using FixYa.
Jul 24, 2010 | Nokia 1100
I have Nokia 1100, battery is dead & won't charge
I am sure if you take this to the nokia care they have an easy replacement for the battery.
Thanks
Fame !
Apr 27, 2009 | Nokia 1100
possible the battery or the charge port itself a phone shop should be able to test it for free
Jun 02, 2008 | Nokia 1100
Not charging
plug is bad or the battery is bad one of these 2 things need to be replaced if you have a car charger try that it will let you know if your battery or charger needs to be replaced
car charger will start chargin battery
May 10, 2008 | Nokia 1100
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Charging
not charging
Oct 04, 2006 | Nokia 1100
Cell Phones Logo
183 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
