Question about Nilfisk Vacuums
How to replace the filter in a nilfisk gd90c - Nilfisk Vacuums
2 Suggested Answers
  • 430 Answers
SOURCE: Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Posted on Sep 13, 2009
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Nilfisk Extreme 300 does not always respond to the remote trigger on the handle
The Nilfisk X300 has a battery in the handle piece it would be worth simply replacing the battery. If that does not solve it you may need a new Nilfisk X300 Handle. It is possible that it is the receiver i teh machine but to be honest these are a pretty hard machine to work on and the circuit boards are all interconnected, this is a repair for an experienced player.
Sep 03, 2011 | Nilfisk Vacuums
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuums Logo
268 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
