Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
I cannot connect to internet. I have orange.
I need to connect to orange on the phone. I have full signal and connection is good on the phone. The only issue os that the internet will not work.
I had orange email me the ip address but cannot get it to work. Please help
    President:
  • 1,884 Answers
Firstly, you must have GPRS activated on your connection. Secondly, only IP address is not required. You need other info as well, eg, port setting,
Posted on Jul 28, 2009
My TracFone want let me on internet say I have no net work I reset it a few weeks ago ant worked after
Are you in a "remote area"? You should be able to verify the signal from the tower to ensure you still have a good connection with Tracfone. Do you also connect via WiFi at your location to the Internet? Maybe your device that enables you to receive a good WiFi signal is not working or working poorly.... One thing to do first is to power off your phone and restart it so that the phone can reinitialize with all the connections it needs to get a good Internet connection. If you live close to a public establishment where you know they have a good WiFi connection, go there to see if it works there. If it does, then you can isolate part of the problem. (your usual location)....where you can check for trouble... If the phone doesn't connect to a public WiFi connection, then the phone might have a problem connecting. Has it been dropped recently? Sometimes, dropping the phone will cause the internal system board to crack, causing damage to the phone. You should also call the Tracfone customer service number and see if the representative can go through some troubleshooting tips with you I hope the choices helped you to find an easy option.
Mar 06, 2017 | Internet Computers & Internet
Tip
My Internet connection so slow?
<p>The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up. <br /> <p>Many Internet providers also offer Fiber Optic Service (FiOS), which connects to the Internet using light over an optical network. In your home, you still connect your computer through copper wiring. The advantage of FiOS is that it can provide higher speeds than traditional copper wire connections such as DSL or cable. Some Internet providers offer multiple options, depending on the area you are in. More populated areas are more likely to have FiOS available. Check with your phone company or Internet provider for more information.<br /> <p>If you use a dial-up connection, there are a couple of good ways to optimize your Internet speed. First, use the fastest modem you can. The fastest modem you can use will send and receive information at a rate of 56 kilobits per second (Kbps). You won't get a full 56 Kbps speed most of the time, but with a good phone line, you should approach at least 45-50 Kbps. <br /> <p>Second, make sure that your phone line is in good condition. If the telephone wiring in your home or business is old or deteriorating, you might be picking up stray signals or cross talk from other phone lines. These problems will slow your Internet connection because the modem will have to send the same information over and over until it's transmitted without interruption. Check your telephone wires to be sure they aren't damaged, frayed, or twisted around power or other telephone cables. If you notice crackling in your phones, you might want to contact your phone provider to have them check the lines inside and outside your home to make sure they are in good condition.<br />
on Dec 03, 2010 | Computers & Internet
My nokia 5230 saying connection error when making a call
Antenna could be broken if its been dropped or some water damage.
But first I'd ring up EE and ask for what they would recommend rather than coming here. They will be able to give you the best advice since it seems like it could be a problem with your contract.
Dec 23, 2012 | Nokia 5230 Cell Phone
What is 3G?
Hi there. 3G is the network your phone is on. Your carrier (like Orange, or AT&T) provides the 3G network for your phone to connect to. What 3G means is that you have a signal from your phone with an active voice and data connection. 3G is faster than the old EDGE network, but slower than the most current 4G networks. Basically, as long as you have the 3G logo on your phone (with a capital G) you have access to the internet and applications that need data to function will work. I hope that helps! Alex
Jun 15, 2011 | HTC HD2 Smartphone
I have an old wannadoo live box on orange worked fine until I moved home. Orange have confirmed that internet has now been set up at my new address and I kept my old phone number. The LAN into my...
i assume you have DSL connection through phone line . double check the cables see if they are connected properly betwee the modem and router etc ..if its all connected then reset your router by pressing littile tiny button at the back of Router and apply new WPA2 password and try connect .
May 12, 2011 | Computers & Internet
I have a problem with my Orange Rio phone. The telpehone and internet connections work fine, but I have an issue with text messaging. I have received several text message, but when clicking on any...
I had the same problem and I rang orange.
They instantly said that the phone needed to be replaced and swapped it for a new one the next day. Service was very good.
Dec 12, 2010 | Cell Phones
Internet error
providing you have a relatively good signal then it is most  definitely down to your settings, your operator can send them to you via sms, i know orange will send them via there website, and also you can do it manually with these settings here.
http://www.ask.com/bar?q=uk+internet+settings+all+networks&page=1&qsrc=121&dm=all&ab=0&u=http%3A%2F%2Fwww.filesaveas.com%2Fnetworks.html&sg=RrT%2FnQcZ4lIUjOa71pz08%2Bt8y64yNCRtAEcchMDDIOk%3D&tsp=1265314061719
hope this helps.
please rate my solution.
Feb 04, 2010 | Samsung SGH-G600 Cellular Phone
No network coverage
j'ai gros problème depuis 1er sept , date de changement de plan orange avec mon iphone (0679186016): pas de connection x 1 sem
impossible de parler à un technicien sur no recommandés par internet : que des répondeurs : as-tu un no de service orange portable à 10 chiffres ou je puisse parler à qqun avant mon départ mardi ???????
merci ++++++++++++ d'avance
F Sestier 1-514-912-4436
Sep 07, 2008 | Samsung SGH-T519 Cellular Phone
Trying to connect xbox live to wireless laptop with full signal. xbox asking for wep address, but will not accept letters only numbers.using orange livebox. spoke to xbox told me to talk to orange.orange...
both xbox and live box hve same recieving connections,both waiting to recieve instructions.purchased cross over cable to plug in xbox and live box. lo and behold connected. works perfect.
Aug 05, 2008 | Video Game Consoles & Games
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
129 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
