Question about Dell Inspiron 6400 Notebook
My laptop battery does not charge.
I have a Dell laptop (inspiron 6400), I changed my battery with a new one (Type KD476 - Capacity 85Wh) but it does not charge, and currently, I rely on the AC adapter to use my laptop. until now I replaced three new batteries and still the battery does not charge. would you please help me fixing this problem.
    Novelist:
  • 148 Answers
If you are able to start your computer with AC adapter that means your motherboard has gone bad, Contact dell support to get a mother board replaced.
Further Queries are welcome
If you think my solution was helpful do rate me
Posted on Jul 28, 2009
  • 102 Answers
Motherboard of laptop get faulty
repair the charging circuit of motherboard
I have "INSPIRON 6400" and
The best and cheapest solution is probably for you to purchase one of the aftermarket batteries you have been researching. While they may be physically compatible, original Dell components are often designed to identify themselves, and they tend to resist being mixed-and-matched. Aftermarket manufacturers have developed strategies to avoid the authentication process.
Before you give up, though, be sure to try this trick: simultaneously press Fn and either F2 or F3 (which ever one has the battery icon printed on it). If you've unwittingly pressed this combination, you may have disabled the charging process. Try it with BOTH batteries--the battery that originally shipped with the Inspiron 6400 may not be dead after all!
Mar 27, 2011 | Dell Inspiron 1525 Laptop
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Hello..i recently purchased a new dell battery GD761/KD476 for dell inspiron 6400. But the problem is that the computer doesn't recognize the battery and says that it is not gonna charge the battery. Does...
Hi
I think the battery you bought is not compartible with your pc notebook that is why you are experiencing such problem.All you need to do is to get to the store or outlrt where you got the battery and get it replaced for a compartible battery or better still you should go along with your system.
GOODLUCK
Jun 21, 2010 | Dell Inspiron 6400 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 buttery does not charge with Windows 7 !!!
Try looking it up in the power options menu in the control panel. There must be some battery settings you can check.
Aug 20, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Aug 01, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 Battery problem
what i would suggest is to check the bios there may be a new flash download on the dell website, my wife has a inspiron 1525, which is plugged in and says not charging, the battery will not go above 0%, but we have had to send it to dell (still under warranty) faulty motherboard. if the bios is up to date, there could be a hardware issue with the battery or motherboard
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Notebook Logo
312 people viewed this question
Alun Cox
