Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
My drill is stuck in reverse
My Makita drill has gotton itself stuck in reverse HELP! I am right in the middle of putting up a new ceiling!
    Sergeant:
  • 384 Answers
Use left hand screws.....or take housing apart to see what has jamed the selector switch.
Posted on Jul 28, 2009
Is there a key to get a drill bit out on an older model Makita
yes it's a JACOBS chuck with a special key in a powertools shop you can buy this
information on
http://www.jacobschuck.com
If you have a drill in a chuck and it will not lose then
place the drill itself (not the tool) in a ,bench screw and take a little bench hammer with the point of the hammer against 1or 2 claws of the chuck and a middle heavy nylon hammer then you beat the machine slowly of the drill .
Succes
May 29, 2014 | Makita Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
How to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Jul 31, 2010 | Makita & 1/2 Inch Drill
How do I change the bit in the Makita 6222D 9.6V cordless drill?
put the drill in reverse hold the chuck housing ( the black plastic piece around the bit) and squeeze the trigger. Hold it tight and it will pop loose, pull out the bit reinsert new one. Put the drill in forward squeeze the housing tigh and pull the trigger it will tighten right up.
Feb 26, 2010 | Saws
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Dec 02, 2008 | Drills
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
424 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
