SOURCE: I need the bolt torque specs
go to the local auto parts store and purchase a Chiltons Repair Manual on your car, it has all the torque specs listed for this. Or you could try the library and see if there is one there for your car and just look it up for free..... just write it all down.
SOURCE: i need torque specs for 94 rodeo
flywheel 80-90 foot lbs (new bolts 90), press plate 45 foot lbs
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
SOURCE: torque specs on replacing cv axle on 05 Pacifica
ok here we go tie rod=55 ft lbs axel nut= 180 ft lbs strut bolts= 65 ft lbs plus 90 degrees
Testimonial: "thank you very much!!!!!!!!!!"
