Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Our carrier light gate is not working in our Wurlitzer 1015.
The carrier light gate does not come on. Our carrier will only turn the C.D.'s, but will not play unless placed on Service. How easy is it to replace the light and where can one be purchased?
  • cauffman346 Sep 24, 2009
    We can't possibly thank you enough for taking the time to provide the information. It was a great resource in getting the problem diagnosed. You were right on! Thanks so much.
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The light is actually a small lamp like you would find in a torch but is a bayonet fitting and tricky to get to. The actual method is to put a piece of rubber tubing on the end of a pencil and push it onto the bulb end of the lamp so that you can then "press and turn" and pull it out. The new one is put in in reverse.
The other method is to remove the front shield holding the sensors. This can be done but you need to prop up the front of the mechanism to get to the screws.
The lamps are not that easy to find but they are not unusual. I think they are actually auto type lamps. In the USA try www.victoryglass.com in the UK try The Jukebox Man in Lincoln.
Posted on Aug 30, 2009
My jukebox worked fine. I moved it to another room, opened the door and let the carousel move by pulling the lever. now it won't play a song but the numbers in the box flash instead of locking on a...
Most likely your light gate lamp is defective. I have these in stock, they are inexpensive, and I have complete instructions for changing it. Please email me for more information, tech@wurlitzer-ohio.com.
Aug 04, 2010 | Wurlitzer Jukebox 1015 One More Time...
Can i change my 1015 wurlitzer from 50 cds to 100 cds
According to my research you may have the option of 200/100 records
Here is the site
http://vimeo,com/3173817
Jul 25, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a 1015 one more time 50-Disc Cd Changer Can my 50 disc changer be changed over to 100 disc changer
Yes, you can convert your One More Time to play 100 CDs. You will need a 100 disc carrier and stop pawl, both of which I have available. Please email me for more information, tech@wurlitzer-ohio.com.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurtlizer k99 turntable spins continously (with the cds) and wont go into test or play mode
If the "turntable" you're referring to is the carrier where the CDs are stored, most likely your light gate lamp is burned out. Look underneath the carrier full of CDs at the front and you should see a faint glow. If you don't, and the K & Z LEDs on the Selection and Credit Computer are constantly lit, you'll need to replace the light gate bulb. I have these bulbs and can help further over the phone. Please don't dis-assemble anything without talking to me, or you may get the light gate assembly out of adjustment. Please email tech@wurlitzer-ohio.com.
Jan 28, 2010 | Wurlitzer Jukebox 1015 One More Time...
Hello i have a omt 1987 1015 lights power up but will not play when you select led shows record to be playing but does not play will not show credits or house hits have checked all fuses none blown have...
Is your 3 digit display on? If not, does the Z LED Flash when rotating the record carrier? If so, you may need to have your computer repaired. If the Z LED doesn't flash, check the 12 volt fuse in the amplifier. If you need your computer repaired or further assistance, please email me, Rod Stebelton, tech@wurlitzer-ohio.com.
Dec 27, 2009 | Wurlitzer Jukebox 1015 One More Time...
Cd holder spins round doesnt select cd
I can help with this problem, but I need more information. Does it just constantly rotate? Are the lights marked K and Z constantly lit on the Selection & Credit Computer? If so, it may be as simple as a burnt-out light gate bulb....I have these in stock and would be happy to help you troubleshoot further. Please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 04, 2009 | Wurlitzer Jukebox 1015 One More Time...
Carrier turns constantly
If you look at the SCC (selection and credit computer) on the right hand side (it's a white box). It has two LEDS (red lights). marked K and M. One flashes every cD position. One flashes every full revolution. If they aren't flashing then your light in the light gate is probably duff.
The light is in the little black box at 6 oclock on the CD carousel as you look at it fromt the front..It's obvious if it is on.
Jan 28, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Aug 16, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
85 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
