Question about Whirlpool Washing Machines
Machine is on but drum is not moving just making a horrible sound...
  • 15,935 Answers
If you can hear the motor spinning, and no drum movement - the drive belt (or coupling if direct drive), or transmission has failed.
It is impossible to determine what drive system you have and the appropriate repair without a model # of your machine.
Thanks.
A Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
Hotpoint aquarius extra
Not familiar with this machine but sounds like failed drum bearing(s). You won't see anything. You must remove drum assembly and separate the parts. If it is a direct drive hope the motor is not damaged
Sep 07, 2013 | Washing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
Hi my machine wma20 makes noise when it start spining. the noise is horrible as lots of bricks are moving along the cycle? how to fix it plz? i have already open it but i dont know how to open the drum...
Remove belt and turn drum by hand, if it is noisy, or feels rough, then main drum bearings have failed.
This a major repair, and not one I would recommend that you do yourself, it involves a complete stripdown, and is quite expensive.
Please rate my solution.
Thanks.
Aug 12, 2009 | Washing Machines
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-Fold® Projector...
Just replaced drum unit in our brother 4750e intellifax, now makes horrible squealing sound when printing. Ideas how to fix?
the drum is not set good please remove the drum and install it again something you do wrong.
Check do the drum is`set good.
Jul 15, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
The washer makes terrible noise when it spins
do you mean up and down? or when you turn the drum like you are spinning it?if it makes a sound like an airplane takeing off or a train rolling through your house. you have a bad bearing which is a very exspensive repair.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Open Questions:
Washing Machines Logo
37 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
