I put in cartridge but it does not still work .the light still flahes on the ink.
  • Paragtraders May 11, 2010
    gevme a printer model
    Problem Solver:
  • 8 Answers
Please give me a printer model and printer softwar is not ditected a new cartridge
Posted on Jul 28, 2009
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Green light keeps flahing
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 22, 2011 | Canon BJC 250 InkJet Printer
Printer would work Flashing lights between green & amber Turned printer off & On printer not in use for some time Put new ink cartridges in
The alternate flahing of the light indicates the the waste ink sponges are saturated. meaning that either you or a printer technician will need to remove the sponges and clean them in water. A tecchnician would most likely replace the sponges with new ones. Therefore one would need to disassemble the printer to get to the sponges. Once cleaned and reassembled you will need to find download and install the waste ink reset software. This software is hard to find as it is given to printer technicians to repair printers.
If you are going to do ths job yourself then read a few guides to get the whole picture, see if you can find a guide of this being performed on your make of printer. Secondly find the waste ink resetting software first, before taking the printer apart.
Better yet if the printer is under warranty, claim warranty support.
Take care!
damnor01
Jul 18, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Flahing E 5 and lights blinking on black and colored ink
Hi, the E5 means that:
The ink cartridges are
not installed[1401],
or a non-supported ink
cartridge is
installed[1485],
or the ink cartridges are
not installed
properly[1687].
Try with diferrent ink crg., Be sure to use genuine. If that doesnt help, the problem is in printer head, or logic board.
Hope that helped.
Jul 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
When i turn the printer on the ink light and paper light are flashing back and fore and nothing works
You should check your cartridges. If one of them is empty, usually the printer won't print. Your cartridges have chips on them, and that chip determines how much you are going to print. Usually, when both lights are flashing, and nothing works, it has something to do with the cartridges.
If that is not the case though, please leave me a comment, as I would love to help!
Mar 07, 2010 | Epson Stylus Photo R220 InkJet Printer
I can't get my hp 960c printer ink light to stop flashing
Remove the new cartridge, inspect the contacts,usually gold little square,this is how the printer talks to the cartridge, make sure there is no ink on it. Where the cartridge ink dispenser is and where it comes in contact with the cartage holder,try and put a little rubbing alcohol on a q-tip and clean the area,
it sounds like some ink has dried there and is not allowing the new ink to come out. Some printers
have another cartridge that holds the ink cartridge, if this is the case, remove both of them for easy inspection and cleaning. If this does not work or not sure, go to the hp website and put in your model#
and search the troubleshooting tips. If that does not help contact them with an e-mail for support.
Hope you get it working.
Mar 21, 2009 | HP DeskJet 960c InkJet Printer
Lexmark 5470 will not recognize a new colour cartridge
Have trawled all over the web...untill I found a sloution that worked for me!
1 Take out what looks like the battery pack ( your wire, plugs into this )
2 Ensure the green light goes out ( two pieces of wire crossing over at the contact point( like trying to fuse the battery ) will make the light go out immediately )
3 Take out the ink cartridge, Clean the ink cartridge with alcohol ( I used GIN! )..clean the internal contacts for the cartridge as well.
4 When dry ( let dry naturally )...put back the ink cartridge
5 Put back the "battery pack" and mains connection into this pack.
6 turn back on....system thinks you are low / out of ink but allows you to print..hope this works for you
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Ink cartridge red light
need original canon ink cartridge not generic
Jan 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530
I am in the same situation. When 'Check Ink' comes up, the yellow cartridge blinks.  If I take it out and put it back again, the printer will work.  Then after a while on idle mode, the problem will show up again.  Pretty annoying.
WF
Sep 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
41 people viewed this question
k24674
jasbo
jasbo
