Question about Minolta Office Equipment & Supplies
Error Message C 50 on a Minolta 1031F copier - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,696 Answers
Fuser code, to reset turn of the machine, if it comes back on the fusing unit the (Hot part) needs to be replaced Upper fuser roller (UFR) carries the lamp. Check the thermistor and thermostat also before replacing UFR
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 09, 2009
Minolta cs pro 1031f error CE 034566
Could not find that in the service manual But might be the main board. Will it scan if the document is placed on the big glass instead of the document feeder.
Jul 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
Minolta EP1031/1031F CS/PRO Copier manual
service or operation manual sir/mam?
Feb 14, 2012 | Minolta EP1031/1031F CS/PRO Copier
Error message f3
just check the panel board botton maybe there is soct up botton
Mar 27, 2011 | Minolta EP1031/1031F CS/PRO Copier
The display is flashing c 50 and not working. how do I fix this. Minolta cspro 1031f
maybe the board connected to fusing unit is broken just replace it that board called board f
Nov 19, 2010 | Minolta EP1031/1031F CS/PRO Copier
It says c then 50
A C5 error code means that you have a problem with the fuser unit. The fuser is not warming up correctly. You will mostly have to replace the upper fuser roller or the upper fuser unit. The heating ubit sometimes arch's though the fuser roller. You will need to resolve the problem before the code clears, you may also have to replace the fuse on a small PCB next to the rear of the copier..... Good Luck
Oct 30, 2010 | Minolta EP1031/1031F CS/PRO Copier
At startup the Minolta 1031F as a flashing C 50 on the screen
Verify the continuity of the fuser heater lamp.90% the lamp is open.You need change the fuser lamp and the fuser roller(the heater lamp is in the roller and is not detachable).
Nov 03, 2009 | Minolta EP1031/1031F CS/PRO Copier
Minolta ep1031 with a C 50 error
http://files.mail.ru/E3J8UV
Read service documentation EP 1035/1031
error C50Warming-up Failure
Faulty Fix Unit reasons:
- no contact or faulty lamp of the heating
- no contact or faulty thermistor
- no contact or faulty Fuse
- no contact or faulty controller of the direct current
The Repair is not simple and is required experienced master of the service, change the adjustments, clear instruction of the regulation of the check. Recommend to apply to service Vinolta Good luck
Oct 09, 2009 | Minolta EP1031/1031F CS/PRO Copier
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
171 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
