Question about Hoover Vacuums
Repair manual for hoover h3000 - Hoover Vacuums
    Top Expert:
  • Hoover Master
  • 44,045 Answers
For a repair manual, contact Hoover directly.
Posted on Sep 06, 2017
ukvacfan
  • 328 Answers
SOURCE: i need an operating manual for my hoover floormate
http://www.hoover.com/pdfs/manuals/H3000.pdf
You will need adobe on your PC/MAC to open this.
Posted on Mar 27, 2009
SOURCE: Hoover Floormate H3000-050 power head/taking apart
I didn't find this as difficlut as red devil 6, however, having 2 people helps. Remove the brush assembly using the 2 brush release buttons. Remove the front nozzel by sliding the 2 nozzel release clips away from the unit. Do NOT remove any screws from the underside of the floor mate base.
Before you begin....on the new wheel assembly, locate the "spring loaded lever" that is attached by the 2 brass screws. Notice that it can be pushed to the side and it locks in place. If pushed again it releases. This is important when you go to make sure the wet/dry pick up indicator is working near the last step of the process.
The top grey cover on the base of the unit lifts off accessing the hubs that hold the handle to the base.
To remove the top grey cover, there are 6 clips that you have to move to one side or the other with a narrow flat blade screw driver. All 6 of these clips are accessed from the underside of the base unit. Work gently...red devil 6 was correct, you can break things easily.
GENTLY pry up the top grey cover exposing the 2 black hubs holding the handle to the base. Remove the 4 screws holding the hubs to the base. I found it easier to have the handle in the down position to remove the cover. I found it easier to have the handle up for 2 screws and down for the other 2 screws.
This is where 2 people come in handy. One person (me) holds the handle and base apart while the other person (my wife) installs the wheel assemlby. It is a little tricky to get in place. My wife found it easiest to install the nubs first (yes nubs, like a little axel that holds the wheel assembly to the base) at the back of the wheel assembly, then slip the pin at the front of the wheel assembly into its position (where the old one came from).
Reset handle and hubs into the base and tighten 4 screws.
Before you go any further, make sure your dry/wet pickup indicator works.....The INDICATOR is the thing that has two red spots on it and tells you if you are on wet or dry pickup. GENTLY TRY to work the wet dry pedal with you HAND to see if the indicator swithces between wet and dry easily. If you are not GENTAl and you force it, you WILL BREAK it. If it does EAISLY go back and forth between wet and dry you have to reset the indicator. Push the indicator stem (the stem that sticks down into the base) up through the base and push the spring loaded lever (see before you begin above) assembly on the wheel assembly to the side. Reinstall the indicator stem and make sure the little spring end is positioned over top of the plastic stub. Recheck GENTLY the function of the wet/dry pickup foot pedal, but use your HAND.
Finally, reinstall top grey cover. It's a little tricky but we found it helpful to have the handle in the down position. Make sure it snaps back into place.
You did it!.
This took my wife and I about 45 minutes to 1 hour....but at least half of the time was spent going slow to ensure I didn't break anything else.
Good luck.
Posted on Apr 06, 2009
  • 190 Answers
SOURCE: I need a operating manual for my h3000 vacuum. Lost by my son.
Glad to help. Please use this link to get the manual:
Posted on Mar 11, 2010
  • 52 Answers
SOURCE: Floormate H3000 Upright Wet/Dry Vacuum: i need operation instructions for hoover H3000 flo...
You can download your complete manual by following the link below.
Posted on May 20, 2010
  • 4 Answers
SOURCE: How can I get a
You can download it in a PDF form directly from the manufacturer's website:
You will require Adobe Reader in order to view the PDF document. If you do not have Adobe Reader, you can download it for free from Adobe's website:
http://get.adobe.com/reader/
Posted on Apr 02, 2011
I need a manual for hoover h 3000
Hi! Follow the link to view the instruction manual for the Hoover H3000. http://hoover.com/file/1703/
Hope this helps!
Jul 09, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How can I get a Manual for the Hoover H3000 Floor Mate Hard Floor Cleanere?
Apr 02, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
116 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
