Question about Sony RDR-VX555
VHS to DVD dubbing
Tried dubbing from a VHS to DVD using the push button on the unit, also went thru the remote. Neither works. When I push the button to start the screen turns gray momentarily then nothing.
  • 3 more comments
  • michael10291 Dec 14, 2007
    I'm having the same problem. what's the solution?
  • NosePicker Mar 25, 2008
    I recorded about 10 - 15 VHS tapes to DVD using the [<-- Video] button. Now when I press it nothing happens. I also tried using the remote and selecting the menu choice and again nothing happens.
    wayne
  • natsoulas Aug 25, 2008
    I can not get my Sony RDR VX555 to dub at all.
  • harrijb Nov 25, 2008
    Cannot dub from VHS to DVD, of, DVD to VHS. Have tried both remote and on machine methods.
  • THECONKLINS3 Jan 11, 2009
    SO MUCH FOR ONE TOUCH
    I PUSH THE BUTTON AND NOTHING HAPPENS
    WHAT IS THE ANSWER?
Press the 'DVD' button then 'Input' button at the top of the remote until 'Line1' or 'Line2' input is selected. I messed with this for quite a while until I finally looked at Sony's web site which states this.
Posted on Jun 10, 2009
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
How can I record from dvd to vcr? Is that possible?
Yes! Just be sure to use the remote, and when you enter "General" features... Look for recording, or Dubbing. Under dubbing... It should allow you to choose which way you wan the recording to go. For example, VHS>DVD or DVD>VHS... Then, install the blank in one side, the movie in the other, and hit the "Dubbing" RECORD button. this should work. Also, most companies now have their documentation, even for very old units, online should you need the instruction manual which originally came with your unit. Good luck!
Nov 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Copy VHS INTO DVD
1. Set up with a new blank DVD.
2. Insert VHS and adjust to the beginning of
your recording.
3. Use the DUBBING button on your remote: you can adjust video quality (2 hours or 4 hours play) at this point.
4. RTFM for use of the PAUSE and DUBBING buttons to skip over commercials etc.
Feb 24, 2010 | Zenith XBR716
Instructions on how to burn from my insignia DVD to VHS
my Insignia is a different model (NS-drVCR) but I always use the "DUBBING" button on the remote (which is basically the tech-term for a Recording-Transfer). The screen-dialog then shows VHS Dubbing to DVD with quality options to choose. I'm not as familiar with going the other way (from DVD to VHS) but I know that mine can since I've done it once with a similar method, starting with the DUB-button.
Jan 11, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Dub vhs to dvd
Make sure that your system is on VHS before you press the dub button. you should then get a box that asks you do you want to record from VHS to DVD and it asks you to confirm this. you press the left arrow button so that the yes box is highlighted and then press enter and your dubbing should begin.
Aug 28, 2009 | Broksonic DRVCR900 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do we dub VHS to DVD without remote?
Fisrt, is it set up already to dub. It willnoe finallize if not. If so then just put a blank dvd in, push dubbing, insert tape, check source to make sure it is going to dvd then push dubbing again
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not copy vhs to dvd
I had the same problem. What I had to do was press the 'dubbing' button on the remote while in VCR mode.
Dec 27, 2008 | Televison & Video
Vcr - dvd player problems
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
Apr 06, 2008 | Samsung DVD-VR325 DVD Recorder/VCR
Sony RDR-VX555 Logo
409 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
