Question about Danby DCR34 Compact Refrigerator
Camper fridge fridge cranks up on elec or gas ..does not cool camper has been in storage 3yrs ?
  • 27 Answers
If it is a 3 way fridge pull it out and turn it upside down and leave for an hour or so and then turn back for an hour or so and continue this for half a dozen times the gas inside the pipes have seperated and require mixing up particually if it is fairly old or has been sitting for a long period as u discribed
Posted on Jul 29, 2009
Fridge does not work on gas or elec Fuse is good have power
If the back of the refrigerator is getting warm and the refrigerator is level then you more then likely will require a replacement cooling unit. You can visit our online Store or give us a call directly 1-888-782-6665 We ship throughout North America!
Sep 13, 2014 | Dometic CS-200 Wine Cooler
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
EARLY 1990 model (RM2652). Camper in storage for
Hello!
Your fridge might be suffering from a bubble, but is unlikely. I am more suspicious that insects (dirt daubers) have built nests on the cooling fins (at the upper rear) and air flow through the fins is being blocked.
Try switching your fridge to LP mode for a day, and see if your cooling performance increases. If so, take a look at the heater, try checking its resistance. Resistance should measure 44 ohms, +/- 10%. While you are checking for insects, also take a look around the burner area of the fridge. You are looking for a white or yellow residue. This would be evidence of a coolant leak, and the cooling unit would need to be replaced.
Given the time of year, air conditioners are being used heavily, including those in trailers. If you are using your air conditioner, and trying to use the fridge as well, make sure that your electrical cord is large enough. You want to use as short of an extension cord as possible, with as heavy gauge as possible (10ga minimum). If you are using an extension cord, or are plugged into an outlet that can't meet the current demands, that will cause voltage to drop. As voltage drops, heater (in the fridge) drops with it. If the output drops too low, there will not be enough heat from the heater to power the absorption cycle for the fridge.
Jul 13, 2010 | Dometic RM2652 Refrigerator
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
Propane refrigerator?
Yes , when the refer needs to cool it will fire up only with the LP. In the electric selection it will work the same way. Do not fret , it is working ok.
Aug 31, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Transported a fridge on its side, waited 24hrs, plugged in.
Transporting frig on side probably damaged the compressor due to the oil inside draining from bottom. Do you know if the bulbs were working before you purchased? If they were you may have damaged the door switch, easy fix, just replace. Compressor replacement should be left to a pro. Probably looking at a couple hundred. One other thought is you might have caused a gas leak during transporting, another job for a pro.
Feb 23, 2009 | Frigidaire FRT18G4A Top Freezer...
Hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Oct 30, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Danby DCR34 Compact Refrigerator Logo
233 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
