Question about Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER,MODEL NO. LER5636EZ2. THERE IS NO HEAT. THE DRYER WORKS FINE OTHERWISE. I HAD THE MAIN HEATING ELIMENT TESTED. IT SHOWED TO BE OK. ANY SOLUTIONS? THANK YOU.DOUG.
    President:
  • 1,273 Answers
Hi Doug, Check your vent hose and both ends of it as well (dryer outlet and wall vent). Take the hose outside and clean it out. Reinstall it with as few kinks and bends as possible. If there is debris under or in the lint trap cavity, remove it as well as possible, This should be what you need.
Regards, --W/D--
Please feel free to rate this solution!
Posted on Jul 28, 2009
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
Whirlpool dryer model LER4634J...will heat fine for 3 or 4 loads in a row, then may not heat for a couple cycles. then work fine again. when i run it i use the heavy/60 min. cycle. when it drys it works...
possible timer, or electrical issue in wall receptacle.be sure wall venting is perfectly clear w/no hinderance to air movement whatsoever .try removing vent hose off dryer for a couple of loads,to bypass venting completely just for testing. otherwise the safety thermostats or cycling t-stats may be in question
Nov 12, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LER3624jq0 has no heat but spins and works fine besides that..fuses are good, the heat coils are getting electricity but just wont heat up.. seems like everything is workin fine just...
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Oct 10, 2009 | Whirlpool Dryers
Dryer won't heat?
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Oct 01, 2009 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer will not heat but works fine otherwise
Could be problem with timer contact for the heaters.
Aug 04, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer Problems
contact the manufacturer. some parts might need to be replaced already.
Jul 13, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
