Question about Panasonic Microwave Ovens
WHERE IS THE THERMAL FUSE LOCATED ON MY PANASONIC INVERTER MICROWAVE
MODEL NN-T945SFX
    Top Expert:
  • Panasonic Master
  • 52,418 Answers
Probably inside
Posted on Sep 06, 2017
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: PANASONIC INVERTER MODEL NN-S76OWF
While your exact model in not available for download, you should be able to find one close enough to work here:
http://panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=87
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: broken door latch on mod.nn-t945sfx
Do you mean the part with hook-like projections that stick out of the door, or the part that holds the door switches inside the oven?
If you need to replace the door latches (the hook-like devices in the door) you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order Panasonic parts from Tritronics here or by calling 866-779-5835.
Posted on Dec 15, 2008
cactus bob
  • 267 Answers
SOURCE: microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Posted on Jan 17, 2009
MicrowaveSvc
  • 9156 Answers
SOURCE: PANASONIC NN-SN789S MICROWAVE INVERTER. IN LOCKED
The owner's manual cover should cover this. if for some reason you don;t have yours, you should be able to download it here.
If you're outside the US, see Panasonic.net.
Posted on Jan 17, 2010
SOURCE: My panasonic over the range microwave model
I have same problem. Disconnect the power. Take the 3 screws out of the top of vented front thus exposing 2 screws that hold down the touch pad .remove them and move touch pad out of the front and out of the way. on the extreme top right within the compartment there is a circuit board that has a fuse on it. replace the fuse and try to restart the microwave. if the fuse blows again you have a major problem probably the magnetron. If you need further help call me (403)870 9110.........Ron
Posted on Apr 30, 2010
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Feb 09, 2017 | Panasonic Microwave Ovens
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
NN-T945SFX
The thermal fuse may be defective, monitors temperature of the magnetron, or the internal fan may not be operating properly, it is possible the magnetron may have a shorted winding.
Mar 22, 2012 | Panasonic Microwave Ovens
The top door latch on panasonic microwave NN- T945SFX broke
it's a replaceable part. the upper and lower hooks are actually 1 part. door will need to be partially disassembled
Aug 03, 2011 | Panasonic Microwave Ovens
We have a Panasonic Microwave model number NN-t945SFX. We were using our microwave as a Inveter Turbo Defroster as we prepared our meal. Seconds after, a family member decided they wanted popcorn since...
NN-T945SFX May 27, 2017
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
If it stops after 7 seconds, it likely has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic Microwave Ovens
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 15, 2009 | LG LMV1314 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Fuse
The fuse is normally located either on the floor of the oven behind the control panel, between the door switches, or on the metal bracket / plate near the large high-voltage transformer.
This model uses an inverter, so the fuse may be located on that board.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 17, 2007 | Panasonic NN-H764 Microwave Oven
Microwave Ovens Logo
305 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
