I have 2 external Altec Lansing speakers for my computer with iTunes and the external (knob) volume control stopped working. The speakers still work.
  • palmovich104 Jul 28, 2009
    Thank you for your prompt response.
    What would a whole new mechanism cost at Radio Shack (ballpark)?
  • 15,935 Answers
This is a simple potentiometer for volume control.
Very easy to fail - and very difficult to repair.
The simplest thing to do is disassemble and try to clean the pot. with electrical contact cleaner... replacing the pot. with a new one is almost impossible - as they do not offer replacement parts.
Try radio shack for a similar one - but it will not be OEM, and may need to be rewired externally.
THIS IS A LARGE SELECTION (click)
To get the proper one - disassemble and obtain the part number off the pot.
You can also remove the pot. - and jumper the wires so the speakers play at high volume at all times - and control the volume with the PC. (just an idea)
Please accept this answer to remove it from the work queue.
Thanks for using FixYa!!
Posted on Jul 28, 2009
  • blueextc3221
    blueextc3221 Jul 28, 2009
    A replacement pot would be around $10
I recently found some awesome altec lansing speakers with a huge sub too. but ... i can't find the volume control knob and without that, i can't make it work !! T___T any solutions? i tried looking for...
Hi there, by saying you found, do you mean that is a complete set, I have the same speaker set, and the volume control knob is on one of the satellite speaker. If you are missing that speaker I doubt that you can do anything with it because you will most likely find them for sale as a set and not separate. Thanks hope this helps.
Mar 09, 2011 | Altec Lansing ATP 3W Computer Speakers
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 13, 2010 | Altec Lansing 2100 Computer Speakers
Low volume on Altec Lansing 4.1 system
if the volume controls of the speaker is set to 100% together with the volume control on your computer then still get a low volume,try some other device where you can use your speaker like mp4,if still got same problem,bring it to a service center there might have a problem with the amplifier.
Sep 10, 2009 | Altec Lansing Multimedia Computer Speakers
Hooking 5.1 computer speakers to a Samsung Plasma
Computer speakers are powered, they have their own amps inside the speaker cabinet.
To get these to work on a TV you need to plug them into a headphone out jack.
The external speaker terminals produce too hot a signal for powered computer speakers. The amp in the speakers may have already been damaged.
May 04, 2009 | Altec Lansing ADA995 Speaker
One speaker not working
jjohnmith
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Feb 01, 2008 | Altec Lansing VS2121 Computer Speakers
Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Jan 23, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ATP 3W Computer speakers
I am also experiencing the same problem as yours...
Dec 01, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
When truning up t3h volume...
volume control knob is damaged inside ,try to put 3drops of kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
Dec 18, 2006 | Altec Lansing VS2221 Computer Speakers
46 people viewed this question
 Grubhead
Grubhead
