Question about Minolta Office Equipment & Supplies
Bizbub 350 fault codec0098 none of the motors run
  • Norman  J Weimar Jr
    Norman J Weimar Jr May 11, 2010
    Are you sure of the code and machine model could not find
  • Minolta Master
  • 1,297 Answers
C0098 : Fusing Pressure Roller pressure/retraction failure.
Relevant electrical parrts:fusing pressure/retraction sensor PC33,fusing pressure/retraction motor M19,controlboard PWB MC or fusing unit.Please check M9 connector,PC 33,PC 34,M19,or if posible change the fusing unit.
Posted on Aug 01, 2009
Bizbub 6501 error code c2823
check the cyan drum potenial sensor located behind the (remove the drum) or the charge wire unit for the cyan drum is loose not properly installed
Jan 05, 2016 | Konica Minolta Office Equipment & Supplies
How long do I run my brand new 350 engine for and how high rpm for first time running
HI the recommended duration of miles to run a new motor will be +/- 500 miles .REV limitation between gear changes during this period safely speaking will be 2500/2750 RPM .
Mar 31, 2015 | Chevrolet 350 ENGINE 5.7 V8 94-95 COMP...
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
What is the part number for a ford f-350 stepper motor?
run your Vechicle Identification Number by your dealership and they will be glad to give you the stepper motor number, availability and cost for installation.
May 17, 2014 | 2006 Ford F 350 Super Duty
I got a ford f 350 6.0 that won't stay running
check for power to the coil with the key in the run position. If there is none check the immobiliser operation and / wire from the ignition switch to the coil . Run fault codes to check for other possible reasons.
May 11, 2014 | Cars & Trucks
Bizbub c352 malfunction detected c0206
open all the draws and check to ensure no paper behind them install the paper properly in the draw DO NOT STORE PAPER ON THE LEFT SIDE OF THE DRAWS ITS NOT A STORAGE AREA IT IS FOR 11 x 17 PAPER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Worse case you blew out the draw motor and main board?
Apr 10, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
2010 ES 350
run fault codes to determine which sensors are faulty.
Feb 03, 2014 | 2008 Lexus Rx 350
Hi my air flow selection switch not working proparely every time i turn on the heat weather i put it on panel vents or floor vent the only thing that truns on is the defroster vent what do you think is the...
its going to be one of two thins either the blend door is broken or the gears in the blend door motor are stripped happens often these little motors only stop once the door is closed or open but i think the timer is offten too long causing them to break the blend door or strip the motor,remove the glove box and watch them work,they are easy to remove once off you can open them up and inspect the gears,usually the one connecting to motor worm gear is stripped out. good luck
Feb 07, 2010 | 2006 Ford F 350 Super Duty
Unsolved fault
check all your paper cassettes and make sure the paper isnt jammed in there or that it is installed properly
Jun 19, 2007 | Toshiba e-Studio 350 Copier
178 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
