Question about Philips Televison & Video
32pfl3403d HDMI Xbox360
Well recently I traded my Xbox360 for one with HDMI. Well I plugged it in and chose optimal resolution, it chooses 1080p. (TV is 1366x768.)
Well just the other day I thought the cable wasn't good quality so I switched it with My HD box's HDMI cable. Boot up my 360 and everything is sharper and I go to display and it doesn't have the HDMI color thing or HDTV settings. It says Resolution's and Reference levels. Went to the first one and saw a bunch of PC resolutions that went up to 1920x1080. All of the resolutions worked (including 1440x900 and 1680x1050 but there were black bars at the top.) Well I clicked 1360x768 and it worked! But I found out there was no sound. Now I messed with it a bit I can't get it back to PC MODE. How can I do this again? tl;dr
5 Suggested Answers
  • 563 Answers
SOURCE: 1080p bush 42 inch tv only displaying 1366x768
1080p refers to the resolution you get when watching television. When you're using the TV as a computer monitor a different resolution scale applies. In other words, television resolution and computer resolution are measured differently.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
SOURCE: Insignia 22'' LED HDTV screen resolution problem with VGA
I think this stems from the fact there is no VGA mode designation (not plug and play) however there are VGA H&V settings that may be overidden from autodect mode under ADVANCED in teh menu. What sux is that it isnt stored and must e reset when input changes. FIRMWARE UPDATE PLEASE INSIGNIA!
Posted on May 22, 2010
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
Posted on Sep 24, 2010
  • 11361 Answers
SOURCE: i own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Posted on Jan 31, 2011
I cannot change my Visio resolution from 720 to 1080
If it is a 1080p TV, then the TV always displays at 1080p. The source device and/or the TV will scale and frame convert the image to match the TV resolution and frame rate. When you power an HDMI device, it reads the TV's supported resolutions and audio formats over the HDMI cable, then it chooses whether or not to scale the image for the TV. The television then receives the signal and performs whatever image processing is needed to match the display needs. With many Source devices, you can use a setup menu to configure whether video should always be scaled up to 1080p. Some people prefer the image scaling of the television. However, if the Source does not upscale, it will limit the resolution of on-screen graphics, such as the program guide. So you'll probably prefer to scale your source devices to 1080p through their menus.
Mar 21, 2017 | Visio Computers & Internet
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ... > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from
Change it: Your Comcast/Motorola HD Cable Box may be ...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
Tablet screen turns off when hdmi hooked up
If running Windows 7:
Right click on the desktop
Screen Resolution
Right click on the screen that is not activated
Choose activate.
Keep in mind that if you want to see the same display on both screen ie dual display then it will set the resolution to the screen with the smallest resolution, which may look a little sucky if you are running 1080p TV with lower resolution laptop screen, the other option is to choose extend screen
Dec 28, 2013 | Proscan Televison & Video
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
During initial setup, after we choose the HDMI option the screen goes black. Work fine connected to TV
Are you using an HDMI cable? If not, your best option is to get one online, because they go for about $59-99 at retail stores.
If you are using an HDMI cable, be sure you are using a resolution compatible with your TV. In display options, when you choose HDMI, you should find a list of checkboxes with resolutions (420p, 720i, etc). Personally, my TV only works up to 1080i, because it doesn't have progressive scan (p). The PS3 may be trying to set it to 1080p which your TV can't handle. Try out different resolutions until it works.
Jun 27, 2009 | Sony Playstation 3 (PS3) Console
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
I was switching my PS3 from using the hdmi cord to using the regular cord so i could use it on another tv. when i switched the cord settings it had to switch the tv settings on the PS3 from 1080p to like...
so u must go n plug the hdmi cable in a tv dat support an hdmi feature so u can be able to fix the problem from the menu.....if it's not lkike that i think u can use the AV cable on a normal TV u can fix it as well
Aug 19, 2008 | Video Game Consoles & Games
Time lag between Playstation 3 and LCD TV.
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source :
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
