SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
SOURCE: Refrigerator stopped working
check if the in side light works and if it does then it is your thermostat.allso check the power supply to your frige
SOURCE: Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp ..
Could also be begining of a defrost problem.
