No , the panel is probably ok .
1 ) remove the ice bin
2 ) in the back of the freezer , you'll see a square hole , with a white rectangle piece inside , which you should be able to lift upward , with your finger . If this piece doesn't lift , then it may be corroded with rust , or be bad . When you call for cubes , this piece lifts up and in the process , lifts the long rod , attached to the ice bin . When the rod lifts , it opens the bin flap , allowing cubes to be dispensed . If it does not lift , the cubes will be ground against the cutters , therefore , dispensing crushed ice .
3 ) to access this solenoid which lifts the cube actuator , remove the 3 or 4 screws on the sides of the PANEL , and with the panel removed , you will have access to the solenoid and actuator .
4 ) you can check the solenoid for continuity , voltage ( when arm pressed for cubes) , or possibly a loose wire .
have ge side/side, water in door dispenser but not in ice maker, disconnected water line at valve to...
(More)
have ge side/side, water in door dispenser but not in ice maker, disconnected water line at valve to ice maker and had water.
I have a GE Profile side-by-side refrigerator/freezer. Ice in ice maker melts, the re-freezes,...
(More)
I have a GE Profile side-by-side refrigerator/freezer. Ice in ice maker melts, the re-freezes, causing huge ice clump.
My fridge freezer is working but not fridge it is warm plus the freezer is not as cold as it should...
(More)
My fridge freezer is working but not fridge it is warm plus the freezer is not as cold as it should be but its making noises as though it is please help
