SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
