Question about GE Refrigerators
GE refrigerator, the temp display was flickering,
GE refrigerator,bottom freezer. The temp display was flickering, now dark. Is this a DIY project?
  • 3,600 Answers
If you are careful and can acess the pannel easily sometimes the pannels are hard to get off, and it would be good for you to have a ohm volt meter and no the safe way to operate around live voltage when testing.
Posted on Jul 28, 2009
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
Continuous clicking sound and light flickers with each click
Replace the main board (mother board) WR55X10656 behind the panel on the back side of the refrigerator.
May 30, 2009 | GE Profile PDS22MBS Bottom Freezer...
GE Fridge Bottom Freezer, works and temp is still warm in Fridge
On most bottom freezer models I have seen, there are vents on the bottom of the refrigerator box under the crisper that return from the refrigerator to the freezer. This allows air blown from the freezer into the refrigerator to return to freezer to be cooled again. It would seem these return ducts are clogged, it might be possible if you have had your refrigerator turned to a very cold setting. When you open the freezer door, you are letting air to be drawn in from the room to make up the air being blown into the refrigerator.
Pull out your crisper drawers and try to locate these vents. Check for debris or obstructions. If you don't see any, try letting the vents sit open for a couple hours to defrost. You could try speeding up the process by blowing through the vents with a hairdryer but I might advise against this because the hot air might deform the foam insulation if you are not very careful.
Jan 08, 2009 | GE Profile PDS22SCRL Stainless Steel...
Its not working!
You are going to need to change the main computer.
Jan 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
