Back to:
Tags:
ASUS Processor Board
Asus P3V4X/S370-133/Tualatin 1.2Ghz (by 2 users)
posted by wilbr on Nov 22, 2007
I am trying to install a Tualatin 1.2Ghz cpu (1.45v) on an Asus P3V4x motherboard using a Asus S370-133 rev 1.01 adapter.
I set the mobo in jumper free mode (JEN pins 2-3 "'ON'') and DIP switches U12 are all ''OFF''.
DIP switches on S370 are set to DEFAULT (1-2,1-2,1-2,1-2,2-3) and the cpu type(J6) is set to 1-2(coppermine).
I use BIOS version 1006.0004.
When I power my PC there is no BOOT, I only get a black screen(in DOS).
Is there a solution to this problem?
Thanks in advance.
Bernie
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ehubert, posted on Feb 17, 2008
I am trying to install a Pentium 3 1.4GHz Tualatin CPU in my old, but trusty, Asus P3V4X motherboard. However, the system frequency multiple is locked at 6.5x and I need to have 10.5x to run at 1.4GHz. Therefore when I am running with a FSB of 133MHz I can only get 866MHz. I know that CPUs may be locked, but why would it be locked at 6.5x when its specifications (per Intel) are to run with a frequency multiple of 10.5x with a FSB of 133MHz? I do have the latest BIOS rev.
Any help would be appreciated. I use a laptop for my daily work but I wanted to “revive” this computer of mine and put the fastest CPU in that I could. If this works then I’ll find some deals to increase the memory and video for cheap. Here are some other details:
Motherboard: Asus P3V4X
-Rev: 1.02
-BIOS version: 1006.004
-Jumperfree Mode
-CPU Vcore: 1.45V
Slocket: Slot 1 to Socket 370 adapter: Upgradeware Slot-T (rev 1.1)
-CPU Voltage (JP1): 1.45 V
-FSB (JP2): 133 MHz
CPU: Pentium III-S 1.4 GHz
-sSpec Number: SL6BY
-512MB L2 cache
-133 MHz FSB
-1.45 V
-I actually have six of these CPUs and the multiplier is locked at 6.5x on all of them.
-My previous CPU was a P3 533MHz Coppermine EB (133MHz FSB, Slot 1).
Memory:
-3 x 128MB Apacer PC133
Video: Riva TNT2 Ultra 32MB
Thanks,
Eric
Best Solution
posted on Dec 10, 2007
FixYa! (100)
Stedman5040
Rank:Apprentice Apprentice
Rating: 100%, 5 votes
The ASUS slocket will not support the Tualatin cpu unless it is adapted for use. You could try a tualatin to s370 adapter in your asus slocket to make it compatible. As the P3V4X has no native support for the cpu either it will not recognise the cpu as a tualatin. My P3V4X sees tualatins as PII cpus.
Rating Locked! (?) wilbr has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Asus P3V4X/S370-133/Tualatin 1.2Ghz:
I don't want to Accept this solution
Solution #2
posted on Dec 15, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
You must use SLOT-T adapter for Tualatin CPU on the MB ASUS P3V4X. And i oc 133MHz 1.8V to 1.6G, very stability.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Processors problems?
Processors
Hi mansoor here, i want to know completely about pentium 5...
Processors
this unit was bought from a casino and the cabinet is...
Processors
hi i keep having a dialogue box appear on my laptop when i...
Processors
no trabaja y cuando llamo a att me disen que el sofware...
Processors
i have this old dell pentium III that i'm trying to...
Loading problems.
Repair Service
Find Processor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
